Question about Miller Welding Tools
Miller bobcat 250 welder with kohler lp gas engine won't idle properly any adjustments for air/fuel mix?
    Scholar:
  • 79 Answers
Make sure that the idle is set at 40Hz. You do this by placing a frequncy meter on one of the 120Vac outlets. If frequency is low, the engine will run rough at idle. There is a 3/8 nut next to carberator that needs to be turned to the right to increase the idle speed.
Posted on May 13, 2009
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
Why is it misfiring?
check to see if carb is flooding, is it black smoking?
Aug 17, 2015 | Miller Bobcat 250 Engine Driven Welder...
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
How do I pull the motor from the generator assembly?
You have to put a wrench on the rotor where it sticks out of the bell housing and another wrench on the flywheel with a tool that miller makes to bolt onto the flywheel. Break it loose and then pull the engine and rotor as one piece off the welder. Then unscrew the rotor the rest of the way and remove it.
Feb 09, 2015 | Miller Bobcat 250 OHV Welder Generator...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
Miller bobcat on propane surges when turned to idle
It might be missing a stabilizing spring on the the throttle shaft to eliminate accumulated play in the components.
Otherwise if no smell of leaking LP is noted, there may be a small vacuum leak in the induction system- can be found with carb cleaner on an idling engine- the area of such a leak when sprayed will smooth out the idle and speed it up momentarily.
If you do smell LP, the regulator likely needs repair or a hose needs replacement..
Sep 14, 2012 | Bobcat Miller 250 Welder Generator 907212...
How to separate the kohler engine from the generator of a miller bobcat 250
The shaft is tapered and will have a bolt in the center, loosen the bolt enough so you can tap on the end of the bolt. This should release the shaft, if not there should be 2 hole that you can thread a bolt into to push the connection apart.
Jun 25, 2011 | Bobcat Miller 250 Welder Generator 907212...
Welding Tools Logo
658 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
