Question about Dell 926 All-In-One InkJet Printer
I put a new black ink cartridge in the printer. When attempting to print, no black ink is being used, just color ink, even though the little level indicator on the printer window the appeared when one prints says the cartridge is not empty. Earlier, the printer told me to take the tape off the cartridge, which, of course, I had already done. Any idea what's wrong?
    Sergeant:
    Champion:
  • 240 Answers
Goto maintenance, on the panel of your printer..choose clean printhead..or wipe your black cartridge with a wet cloth..maybe your cartridge suffered clog that covered the nozzles ..
Posted on May 13, 2009
The printer keeps doing the alignment and saying that there is a problem. My color ink cartridge is low but I would still like to print with black ink. I don't know if the color cartridge being low affects...
Replace your color cartridge and power printer on. The color cartridge is probably empty (even though there might be a little ink left in it). Many inkjet printers require the color cartridge for composite black even if you are not printing in color.
Jun 16, 2010 | Dell 926 All-In-One InkJet Printer
I recently replaced the black ink cartridge and do not wish to use the colour cartridge. However, the printer still keeps flashing the critically low level of my colour cartridge and does not print.How can...
Many printers always use a small amount of each color even if you are only printing black, to prevent the color nozzles from drying out and getting clogged (and, it forces you to buy more ink, which is a profit center for printer manufacturers)
For this reason, some printers will not work if ANY of the cartridges are empty.
It should work again if you replace the color cartridge. Make sure to select "black ink only" or the option to print in black and white or grayscale to minimize color ink usage. It may still use a little, but that's OK.
Apr 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
How can I over ride my ink level tracker on the Kodak ESP 7 printer? The printer must be using a counter because I never print in color but my color cartridge keeps showing that it is going down. ...
The Kodak printers are designed in such a way so as to work with combination of Both color and black ink..In other printers,the prints are not that sharp,but In kodak printers color are awesome because even if we print black and white,the color from the color ink is also taken to give you those lifetime prints.Unfortunately There is no way to overcome this ink indicator.You cans et the preferences in the printer settings to print in black and white in your computer .
Dec 30, 2009 | Kodak ESP 5 Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Black Cartridge Not Being Used While Printing
try printing in monochrome mode or gray-scale mode, and specify that it use only the black cartridge.
another problem could be that the head have gotten dry, remove the cartridge, get a soft cotton towel, wet it with a little bit of water, put the head of the cartridge (where the ink comes out from) on the cotton towel, you will see some ink come out of the cartridge, if yes, then put the cartridge back into the printer, and give it a try.
if not try to blow some air into the cartridge as if doing CPR ;) to the cartridge, this will help the ink get out of the cartridge.
if all this fails, get a new cartridge, as sometimes the head could have gotten damaged.
good luck
Mar 25, 2009 | Dell A940 All-In-One InkJet Printer
Maybe you can try to rest the black ink level 1st. To reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
Jan 14, 2009 | Lexmark X2500 All-In-One Printer
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Dell 926 All-In-One InkJet Printer Logo
219 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
