Question about Pelonis WM-HO202C Oil Filled Radiator Heater
When temperature is placed on HI, very little heater comes from heater
When heater is on high temperature, very little heat comes from heater
I need a new heat selector switch
Posted on Jan 12, 2010
    Sergeant:
    Champion:
  • 214 Answers
If the fan is blowing air normally, but the heat is less! than you need to replace the heating coil of the heater. i'm sure your problem will solved................have a nice day:-)
Posted on May 14, 2009
Little heat coming out of vents.
IF YOU CAN'T FEEL THE AIR FLOW OUT BUT YOU HEAR THE BLOWER MOTOR WORKING, BEHIND THE GLOVE BOX IS A CABIN FILTER.REPLACE FILTER
IF YOU HAVE GOOD AIR FLOW BUT NO HEAT:
1;VACUUM LEAKING TO HEATER CONTROL
2;WATER PUMP GOING BAD / NOT CIRCULATING COOLANT,HIGH RPM/MORE COOLANT TO THE HEATER CORE
3;OPEN THERMOSTAT/ENGINE TEMPERATURE TO LOW
1;CHANGE THE DIRECTION FROM VENTS TO FLOUR TO WINDSHIELD. IF NOTHING HAPPEN IS THE VACUUM
2;RUN THE ENGINE INSIDE ON WARM PLACE ON IDLE.NOTE THE GAUGE IF PAS 1/2 TO 3/4. IF PAS 3/4 MARK REPLACE WATER PUMP
3;IF GAUGE STAY BELOW 1/2 REPLACE THERMOSTAT
GOOD LUCK
Mar 27, 2014 | 2005 Dodge Neon
Constantly running without shutting off in economy mode
check the temperature control bulb that is located on the rear of the unit at the bottom near the power cord comes out of the unit. a thin gray wire maybe three feet long at the end is located the little glass black bulb. you will have to place this bulb where it can monitor the room temperature. if it is to close to the heater it will cut of whit out heating the room and keep coming on. like wise if to far way or in an area that is to cold then it will keep running. you will have find the right placement for the sensor bulb. it may take a little time.
Dec 15, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Lg dle8377wm over heating
You will need to replace the "high limit thermostat". Under normal conditions, the dryer's primary operating thermostat will cycle the heater on and off to prevent temperatures from rising too high within the dryer. The hi-limit thermostat will remain unaffected through all of these cycles, since the temperature inside of the dryer will stay lower than what is required to activate the hi-limit sensors (generally 250-degrees Fahrenheit, though the exact temperature may vary on some dryer models).
Here is the part you need to order.
Nov 09, 2012 | Dryers
How do I know that Malibu 99 Radiator Thermostat needs replacing?
if you have little or no heat from your heater, the thermostat is open and bad, if it is stuck shut the temperature of the radiator up top will be colder by alot than the bottom-you can also check the top hose coming out of the radiator when the engine is warned up, it will not be very hot and the engine temp gauge will read very high. the best way to check a thermostat is to remove it and place it in a pan of water, heat it on a stove-a 192 degree thermostat starts to open at 192 ans should be fully open at 210 degrees.
Aug 06, 2011 | 1999 Chevrolet Malibu
I do not have the manual to my fan forced heater (model HF-0034) and I am not sure how to work it. It keeps shutting off after a few seconds of heat. Then it will turn on again in 10 minutes and back off...
A lot of this, may be caused by the temperature setting and where the heater is placed. If the temperature is not set high enough, as opposed the ambient room temperature, it probably only turns ON briefly. Also, if the heater is placed near a heat source or in direct sun light, it's sensing the temperature from those sources, rather than the room air.
Try moving it to a another location and setting the temperature on the unit a bit higher.
Hope this helped you to solve the problem. Please let me know.
May 06, 2011 | Pelonis Heating & Cooling
My heater is not working. When I turn it on the caution red light comes on and it does not heat up
It is possible that a little safety device inside has opened up, now allowing current to pass on into the heating element.
Are you handy with opening the cover plate, and looking inside for a few possible failed parts?
Often there is a little device that looks like a small glass fuse, (About 1/4" in dia. and a little over an inch long..) but it is more than just a fuse-- It is also a High Temperature limit device-- (It will have the temperature stamped on it, in Celcious) -- If that has opened, -- it will have to be replaced.
Can you check it with a Continuity checker?
Let me know how far you care to go in repairing this device.
Mack B
Jan 15, 2011 | Pelonis WM-HO202C Oil Filled Radiator...
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
Where do I set thermostat when temp is 10 degrees outside?
Setting a thermostat has nothing to do with outdoor temperature, but more to do with what is a comfortable setting for you and your utility bill.
A common misconception associated with thermostats is that a furnace works harder than normal to warm the space back to a comfortable temperature after the thermostat has been set back, resulting in little or no savings. This misconception has been dispelled by years of research and numerous studies. The fuel required to reheat a building to a comfortable temperature is roughly equal to the fuel saved as the building drops to the lower temperature. You save fuel between the time that the temperature stabilizes at the lower level and the next time heat is needed. So, the longer your house remains at the lower temperature, the more energy you save.
Another misconception is that the higher you raise a thermostat, the more heat the furnace will put out, or that the house will warm up faster if the thermostat is raised higher. Furnaces put out the same amount of heat no matter how high the thermostat is set; the variable is how long it must stay on to reach the set temperature.
In the winter, significant savings can be obtained by manually or automatically reducing your thermostat's temperature setting for as little as four hours per day. These savings can be attributed to a building's heat loss in the winter, which depends greatly on the difference between the inside and outside temperatures. For example, if you set the temperature back on your thermostat for an entire night, your energy savings will be substantial. By turning your thermostat back 10 to 15 degrees for 8 hours, you can save about 5 to 15 percent a year on your heating bill -- a savings of as much as 1 percent for each degree if the setback period is eight hours long.
Hope this helps..........
Nov 23, 2010 | Goodman GMS90703BXA Heater
Reset button needs reset daily
Thermostat may need replacing in order to take care of this issue.
You may try turning temperature down a little and see if it will stay on. Temperature may be set high and heater heating beyond limit and tripping it out.
More than likely theremostat is going bad.
May 28, 2010 | RELIANCE ELECTRIC WATER HEATER
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
May 31, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Pelonis WM-HO202C Oil Filled Radiator Heater Logo
293 people viewed this question
Top Pelonis Heating & Cooling Experts
paulcarew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
