Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My zero turn mower is not as fast as it was just changed the drive belt but it didn't help.
  • 323 Answers
Although you'd think a new belt would do the job, there are a lot of other things that can cause your mower to slow down. I have a Cub Cadet myself, but it is a 1500 garden tractor. When mine began slowing down, I figured the belt was stretched and put a new one on.
If you go to www.cubcadet.com, take your model and serial numbers, you can download a parts maual and a service manual. One will show you what the other doesn't.
You'll see there are a myriad of adjustments to be made. The operator's manual will tell you there is no adjustment. Ain't true. When you get those manuals and have about two hours to spare, look up the section with drive belts in it. There you will see how it's done. Good luck!
Posted on May 13, 2009
  • Dan Todd May 13, 2009
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
Frayed traction drive belts on a zero turn, joy stick snapper. How do I change the belts.
take it to someone that knows these... they aren't easy or easibly explainable !!!
Sep 30, 2013 | Oregon Scientific Oregon Gator Mulcher...
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
How to replace the drive belt of a t zero turn riding lawn mower
Remove the idler spring under the machine and remove the deck belt and keeper.
the belt will come off easily after that. If you have questions see a dealer like www.arcolawn.com
Good luck
Joe
Nov 05, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
371 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
