Question about Sanyo DS27510 27" TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
No remote trying program my antennea channels,cant switch from video 2
  • 579 Answers
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
Posted on May 31, 2009
    Problem Solver:
  • 4 Answers
Get yourself a universal remote, program the TV and you'll be in business.
Posted on May 15, 2009
  • Chrissy
    Chrissy May 29, 2009
    If you want, and I'm not endorsing anybody or anything, but one site that comes to mind is http://www.oneforall.com. The thing I like about this brand of universal remote is that they have a wide range of remotes (pricewise) and you can just about always find the codes for your equipment. And if you happen to lose the booklet, you can always go onto the website and look it up. Hope this helps.
How do i program a universal remote to my sanyo t.v without the t.v code
Hello
Three digit universal remote code for Sanyo are:-
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:-
0049 0097 0110 0004 0268 0012 0108 0180
Try each code after switch the TV Off by its power switch and switch it On again until you find the suitable code for your TV, keep that number safe for further use.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Dec 12, 2010 | Sanyo DS31520 31" TV
Programing remote control
Since you obtained a used TV, there probably wasn't an owner's manual with it. Here is the site where you can read and/or print the manual. http://www.sanyoservice.com/pdf/images/DS27510(OM)_excluded_French.pdf
On page 6 in the Quick Tips column, the second tip states: If the remote control does not work: Press TV key (see item 1).
Good luck resolving your problem.
Jan 29, 2009 | Sanyo DS27510 27" TV
Can't switch from aux to video.
The universal remote will not work because there has to be an input button on it.
Aug 24, 2008 | Sanyo DS13204 TV
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Jan 17, 2008 | Televison & Video
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Jan 08, 2008 | Televison & Video
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Philps Universal cl034 needing codes
i need the tv code(toshiba tv) for my phillips universal remote control model CL034
Dec 28, 2007 | Philips RC2573 Remote Control
Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Sep 06, 2007 | Sanyo DS31520 31" TV
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Sanyo DS27510 27" TV Logo
943 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
