Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
How can i find the leak
Water is leakinf from the inside of the heater when the pump is running
  • 3 Answers
Take the top part of the heater off, this will expose the manifold and heating coils. If you did not perform a good winterizing job the manifold cracked due to freezing water expanding.
This happened to me, I took the manifold off which is cast iron and took it to a welding shop, for $65 US dollars it was repaired, I reinstall everything and I'm up en running.
You can do this yourself if you have some basic tools.
All in all I spent $163 dollars getting my heater going. Its better then paying $1400 - $1500 for a new one.
At the end of the season I will be doing a better job getting the water out of the heater before first freeze.
Best of luck!
Posted on May 20, 2009
No heat in acura tl
Check coolant level...next would be replace thermostat, then if needed flush and refill radiator/cooling system...any leaks?
Oct 07, 2015 | Acura Cars & Trucks
I have a 2006 pontiac grand prix and it is leaking coolant and we can not find where it is leaking from. We replaced the water pump gasket and it still leaks. It looks like it is leaking from something...
have a pressure test done so that you can see where it is leaking from.. If it is in the side of the block it may be a rusted welsh plug. Check inside the car for a leaking heater core and hoses . Check the drain hole under the water pump as it may be leaking from that hole while the pump is running ( water pump seal)
Feb 22, 2014 | 2006 Pontiac Grand Prix
Water leaking from passanger side running hot cant locate water pump
water pump may not be external , but is behind one of the pulleys, have you checked for loose or cracked hoses? do you hear any noise coming from that side? don't forget the heater hoses, and is the leak on the inside or out?
Oct 20, 2013 | 2003 Oldsmobile Alero
Water pump is leaking. Do i have to buy the whole set? Can i find only parts? Is there a way to fix it? Its leakinf from that little whole it has in the bottom.
The little hole is a drain. Your seal is very likely leaking. You might try some stop leak product or you can replace the pump. I don't think the seal can be replaced. If this were my 2003 Classic Honda 900 Hornet, I would go to the Honda Shop and see what the friendly guy or gal at the parts desk had to say about this repair.
Mar 04, 2013 | 2003 Honda CB 900 Hornet
Have a 94 Buick century. Replaced thermostate. Running hot. Looks as tho is leaking underneath front near pump. And also in passenger floor board can't see the leak from inside. It's just alwa
Whenever I see a system which is leaking from more than one or two places, I do a head gasket check because that tells me that the system is experiencing above normal pressures. the wet floor is a heater core. whether it's a water pump or some other thing near it only you can tell. Actually it rarely happens, but the wet floor could be the hose where it meets the heater core at the firewall; again, only you will be able to tell the difference. if the hose connection looks dry, assume that it is the core itself.
Mar 03, 2013 | 1994 Buick Century
Is there a way to know wheither its the water pump or a hose if you car is losing antifreeze? The car doesnt seem to be leaking when it is idle in the parking spot but when i come home frome a ride the...
it could easily be burning the antifreeze through a bad head gasket. if when warmed up the upper hose is quite stiff indicating the system is under pressureand you shut it off,even waiting until the radiator fan comes on and then right away turning of the key,wait and see iff anything runs out.the water pump would have to be looked at from below while the leak is ocuuring= reason must mechanics suffer a lot of burns. or with a sall extendable saft mirror. you could also loose antifreeze from a heater core leak but that would give a lot of steam on your windshield inside in the cold weather,or the carpet would be wet inside the car
Feb 21, 2010 | 1991 Chevrolet Beretta
BMW 1995 318i - Car Running Hot
There is a blockage or leak in your cooling system. That may come in a few different forms:
Incorrectly installed thermostat
Water pump not functioning - you may see water dripping from the pump or a stain from the hole under the water pump.
Severely coroded hoses/coolant passages - if the fluid is brown and the inside of the radiator rusty
External leak - you would see fluid on the ground Internal leak - you would see steam/white smoke from the tail pipe or water in the oil (may look like chocolate milk or not), if the oil level is extremely high this would be a good indication
heater core bypassed
Jan 06, 2010 | 2003 BMW 5 Series
Wasn't no problem with untel i replace my water pump. as i finish the water pump job i turn the truck on and feel it up with antifreez and at same time i turn the heat on and smell of entifreez comes out...
You have an antifreeze leak. Probably in the heater core (a small radiator inside of the dashboard that heats the air as it passes through). When the engine is running do you see any steam around the engine? Or smell the sweet antifreeze smell around the engine? If not then it is probably the heater core instead of a hose or somewhere on the engine. Does this truck have the option to switch the heater to recirculate he air inside the cab instead of drawing in outside air? If it does then you can set it to recirculate the air inside and if it still has the smell then its definitely the heater core. Often with a leaking heater core the passenger side floor and firewall area will get wet, but not always.
Sep 11, 2009 | Dodge Ram 1500 Cars & Trucks
98 pathfinder water pump
Chances are if you have a coolant leak right under the water pump, especially with engine running, the inner seal in the water pump is shot & the entire water pump will need to be replaced with a reman / new one. For the amount of hassle required to replace the seal it is worth the couple hundred bucks for the new pump.
There would definitely be overheating problems if the pump were not working at all. You will also have overheating problems present if there is low coolant, make sure the rad is topped up, with heater(s) on "Hot" inside & run the engine until it shows warm on the gauge. Make sure all of the belts are tight & pump looks like its spinning.
Mar 29, 2009 | 1998 Nissan Pathfinder
Heating & Cooling Logo
79 people viewed this question
Top Lite On Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
