Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Data Cable cut on ACER AL1715sm
Hi, I have Acer AL1715sm and the cable is cut. About 5cm from display. The story is that this monitor was stolen and I lost my hope to see it ever again. Those bastards cut the cable and left me a cable attached to PC. My PC is behind the wall and wires are going through wall to monitor in other room.  So I threw away that cable what was left. But one day police called me because they found my monitor and other stuff!!. So now I just have this monitor with cable cut on the back. I have opened it and all I could find out that there are colored wires (all of the different color) and don't know how to find out which wire is which . Please help me!! Thank You.
    Problem Solver:
  • 11 Answers
Re: Data Cable cut on ACER AL1715sm
Hi, I have AL1716 so pretty the same - both cables (power and analog VGA cable) are inserted into sockets, probably your VGA cable can be screwed in - just unscrew it and go to nearest PC shop to buy new one. What a good cops you have !!
Posted on Dec 07, 2007
0 characters
3 Points
Connect my Acer monitor to my digital cable box.
Not sure what your cable box outputs but connect your cable box to a tv and try changing the resolution of your cable box to 1600x900 or less if there is such a setting; the monitor will not display resolutions higher than 1600x900
May 08, 2014 | Acer X203H bd Monitor
Is it possible to rotate the screen (acer al1715sm) from its base? (to srew on the wall) cause mine moves up and done, but gets stuck after a small bit..
find audio multimedia base like VG3P31 (Philips) std. 4 screw mount pedestal like photo below..move up/down, CW, right/left.659ae0f8-3ebc-40d3-ad3a-1dd9b380bafc.jpg
Oct 17, 2013 | Acer AL1715 Monitor
Monitor says no signal
1) Check your VGA (Data) Cable it will be fix properly in both of side.
2) Change the VGA cable..
May 25, 2011 | Acer X203H bd Monitor
Cable not connected
make sure the data cable is firmly connected to the pc, if yes then your data cable is faulty. look for bent pins or cable cuts. also test on a known working cpu, if all fails take it to a repair shop
Oct 27, 2010 | Acer V193w LCD Monitor
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
Hi guys. i hav an acer ac713 crt monitor. the cable that connects the monitor to the tower/hardrive has been cut by burglars. where can i find a wiring diagram to fix it? thanx.
in 15pin connector of the monitor,
red wire goes to pin No:1
green wire goes to pin no:2
blue wire goes to pin no:3
yellow wire goes to pin no:13
white wire goes to pin no:14
and black wire goes to 5&15. Now display will come!
Sep 08, 2010 | Acer AC713 17" CRT Monitor
you are in a bad spot, the plug is sealed when molded. maybe ebay has a defective monitor and you could take the cable off it.
Monitors will usually snap apart with a butter knife.
Jan 27, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
Acer monitor cable/ accessory
the best way to do what you are describing it to have 2 display adapters installed...and use your 1st display for your monitor and the second for the digital receiver..... then you would optimal performance and have more video memory for each display allowing faster productivity
Jan 07, 2009 | Acer AL1916W 19" LCD Monitor
Phillips VGA Cable colour chart
you can use any vga monitor with the same color output and resolution setting just goto craigs list in your town and look for someone throwing one out detach old cable and reapply to your screen by either soder or splicing the wires independently together this is tricky
Pin Name Function 1 RED Red video 2 GREEN Green video 3 BLUE Blue video 4 n/c not connected 5 GND Signal ground 6 RED_RTN Red ground 7 GREEN_RTN Green ground 8 BLUE_RTN Blue ground 9 VDC 5 VDC supply (fused) 10 GND Signal ground 11 n/c not connected 12 SDA DDC / I2C data 13 HSYNC Horizontal sync 14 VSYNC Vertical sync 15 SLC DDC / I2C clock
Jun 02, 2008 | Philips 107E66 17" CRT Monitor
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
333 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
