Question about Panasonic KX TGA100N Cordless Expansion Handset (KX-TGA100N)
Lost our manual and can't figure out .))) no item and to save the time
My kx-tga181al i need a manual to identify the different screen menu items and how to work .)))no item thanking you
Thanks anyway but panasonic solved the problem with a information booklet
Posted on May 13, 2009
Coby 8127 forgot pattern pass code S/N 043130000741
1. With the pad OFF depress the "-" key on the volume control and the power button at the same time and HOLD them down until the "Coby" splash screen comes up. 2. KEEP HOLDING THE "-" key down and RELEASE the power button until an android is displayed lying on its back. 3. RELEASE the "-" key and press the " " key on the volume control You should see the Android system recovery options on the screen. 4. After the menu appears, select the "wipe data/factory reset > Yes " menu item by pressing the "-" key until the cursor is on the line 5. Press power button to select 6. After it goes through resetting, using the volume key to navigate to the "reboot system now" menu item 7. Select the menu item by pressing the power button to select 8. Your mid9042 will now boot to an unprotected screen, BUT you will have lost any applications you downloaded. You will, however, save all pictures, etc. you have loaded. .
Mar 09, 2015 | Coby MID7036-4 - Kyros MID7036-4 7 4 GB...
My polariod 1700lcd TV will not change from air to digital signal how do I change this
I would have thought you could just select a different source from the remote. Can't you do that? Usually press the source button a few times to go through the different options on the screen.Need to select the analogue tv through the antenna or else digital tv through the set top box I guess so you would need to select the right source where the box is connected..
Did you do the initial set up and let it auto tune all the analogue channels when you first plugged it in.
I found this in the online manual but the preset button is one of the 3 menu items you can't select so you may not be able to follow this instruction any way.---------------------------------------------------5.Air/Cable selection
You can select the signal receiving method according to the following steps:1) Press the MENU button to enter the main menu.2) Press the button to select the itemPRESET, and press the button to enterPRESET menu.3) Press the button to select the item tv source.4) Press the button to change the item among air, catv s, catv h and cath i.6.Channel search------------------------------------------------have you checked if the parental lock is on or if some of the channels are locked out from the initial channel set up screen?
Saw someone else make a comment that they got the tv new and it had a vchip blocked when they first got it out of the box and lots of channels were locked off and took him 2 hours to figure out how to unlock it from the menu. Didn't say how he did it unfortunately.
This is the manual if you don;t have one already any ways.
http://tv.manualsonline.com/manuals/mfg/polaroid/lcd-2000.html?idRes=606769
Hope you can figure it out.
Mar 24, 2013 | Televison & Video
I need a game manual for shining soul 2. i lost mine and i have forgotten how to use my summons
Shining Soul 2
FIELD CONTROLS
Control Pad Move character
A Button Confirm/Talk/Pick up/Attack. Charge Attack (hold). Shining Force (hold).
B Button Cancel/Use items/Throw (hold)
L Button Display & select ARM equipment
R Button Display & select ITEM equipment
Start/Pause Display Camp Menu. SELECT = Use equipped Soul
CAMP CONTROLS
Control Pad Move cursor
A Button Confirm
B Button Cancel
L Button Select ARM equipment (Item Screen)
R Button Select ITEM equipment (Item Screen)
Start/Pause SELECT = Scroll through item descriptions
Mar 10, 2011 | Video Game Consoles & Games
How do I remove an item from happy hour on restaurant pro express
Go to OPTIONS, select SETUP, then TOUCH SCREEN CONFIGURATION. Assuming you have a different schedule for HAPPY HOUR, select that schedule on the right side of screen. Then click on ITEM & DEPARTMENT button. On the left, HIGHLIGHT the department your item is in. On the right, HIGHLIGHT the item you want to remove from your HAPPY HOUR menu. Near the bottom on the right side, uncheck box DISPLAY ITEM ON TOUCH SCREEN. Click SAVE AND EXIT. This should remove item from HAPPY HOUR menu, but not any other menu. Item will still be listed in inventory. You can re add it by just checking the box again.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Mar 09, 2011 | Pc America Restaurant Pro Express
Diablo 2 cheats to get a powerful armor and items
these are the only cheats, not really cheats, but its worth it:
  • Windowed game Start the game with the "-w" command line parameter to run it in a window on the desktop.
  • Cow level Successfully complete the game to get the Horadaric Cube. Then, obtain "Wert's Leg" in Tristram (where you go to rescue Deckhard Cain). Go to the northwest part of the town and search the boy's body. Place both Wert's leg and a Tome of Town Portal in the Horadaric Cube, and it will open a portal to a hidden level filled with axe carrying cows. Do not go through the portal until you are over level 35 because the cows are quite numerous and strong.
  • Imbue without worry When you get an item and want to imbue and are worried about the outcome, copy the "Save" folder from the Diablo 2 folder to the desktop or any other location. Start your game and imbue. If you do not like what happened, save the game and exit. You will now be at the main menu again. Press [Alt] + [Tab] and copy the save folder back to its original location. Then click "Single Player Game" and start. You have another chance to imbue the item. Repeat this until you get the desired effect.
  • Retrieve items after death Save and exit the game after dying. Restart the game, and your corpse will be in town, allowing you to retrieve your possessions.
  • Avoid no-win situation Press [Esc] when facing imminent death, then save and exit the game. Load the game again to start in town, where you can buy weapons, life, etc.
  • Gain money and items quickly Travel past the Blood Moor and look for a cave. The cave has two levels, with a golden chest somewhere at the second level. Inside are usually health potions, mana potions, scrolls of town portal or identify, unidentified weapons and armor, and sometimes even a rare item that can be sold for a great deal of money. If you identify the item and it is something that you do not want, sell it. Save and exit the game. The next time the game is loaded, the chest will still be there with different items. This can be done as many times as needed.
  • More money for items Identify or repair items before selling them.
  • Infinite one way portal Cast a Town Portal from a safe location, then take the portal into town. Use the waypoint system and run to get back to your last location. This allows you to use the portal to go back into town an unlimited number of times as long as you do not use it from town to return to where you were previously.
  • Duplicate items Note: This trick only works in an Open Battlenet game, as the characters need to be saved on your computer. This trick also requires two computers with two copies of Diablo 2. Get the items to be duplicated. Copy the "Save" folder from the Diablo 2 folder of that computer and paste it on your desktop. Go online with both computers and meet in a game. Give the items to be duplicated to the second computer, then save and exit. Press [Alt] + Tab] on the first computer to switch to Windows and copy the "Save" folder from your desktop back to its original location, overwriting its current contents. Return and join the other computer in the game. You will now have all your original items and the other computer will have a copy of them. Note: This does not work with the +1 Skill book from Act 2, as you are only allowed to do it once.
    Note: This trick also only works in an Open Battlenet game. Take the item to be duplicated and place it in your inventory. Then, save and exit the game. Next, come back to the game or join a different one. Drop the item you want to duplicate. Make a note of the game name and password, then sign off of your ISP -- do not save and quit the game. Have another person in the game keep it open while you are logged off. Sign back on to your ISP, go back into the game, and pick the item that you dropped. It will also still be in your inventory, so you now have two copies of that item.
  • May 26, 2010 | Computers & Internet
    Media card
    If you inserted your sd card corectly, you should be able to save items to it as long as it is not a defective unit. Do the following:
    1) From the Home Screen Menu, go to Settings, then Options, and scroll down to Media Card and choose it with the trackball.
    2) From there you will see the Media Card configuration options which allow you to set the Media Card Support, as well as the Mass Storage Support option. Also, you will be able to confirm from this screen if the phone is recognizing the presence of your sd card. Hope this helps.
    Aug 21, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
    I need a user manual for a KX TG1100E
    you tell any option you want and i will send it
    Jun 29, 2009 | Panasonic KX-TG1100 Cordless Phone
    How do you turn on caller ID on a Panasonic KX TGA181AL
    Is your phone operated off a panasonic system? is so you need a caller id card. if not then you would need to inform your phone service provider that you need caller id. if you have caller id and you do have the caller id card you would need to get a hold of a panasonic tech who could turn on your c.id as long as it is being provided from your phone service and the card is installed.
    Feb 20, 2009 | Panasonic Lands Phones
    Lens & screen show black instead of item to be shot.
    You need to go into the menu function to turn the screen on (this feature saves the batterys)
    Dec 08, 2008 | Cameras
    Panasonic KX TGA100N Cordless Expansion Handset (KX-TGA100N) Logo
    581 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
