Question about Craftsman Garden
Need to adjust fuel and air mix to start trimmer.
Hi I have a Craftsman 32cc weed eater that will not run at a fast idle. It will stop when I increase the speed. I would like to do a complete adjustment from scratch on the high and low idle. The plastic over run caps that come on the adjustment screws are missing. Note I have adjusted on it to where it will not start now so I need to do the rough set and then find tune after I get it started.
  • 246 Answers
Hello gwturley201:
I am Including the Carburetor Adjustment File Also.
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holding it to the Carburetor Body.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade or for Chainsaws and Trimmers; they Operate without Bogging Down. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
3 Suggested Answers
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
I need a trigger for a craftsman weed eater
Go to http://www.searspartsdirect.com/
Select model number and her your model to look-up the part number and you can then order the part from them or some other dealer using that part number.
Oct 16, 2014 | Craftsman Convertible 32cc Gas Line...
Weed eater troubleshooting
Check the ground wire from the switch. The kill switch uses ground to kill the engine.
Aug 20, 2014 | Craftsman Convertible 32cc Gas Line...
Why won't my FeatherLite FL-20C weed eater will not stay running when I put it in full choke. What could be wrong?
It should run ok after warming up. After starting it, let it run for a minute or so and then try gradually opening the choke. You might try increasing the throttle setting at the same time. After the motor is hot, if you have to have the throttle setting increased in order to keep it running it means the idle setting needs to be increased, usually by turning a screw to keep the fuel valve from closing so much, or that there is a problem with the fuel flow......like a clogged jet or fuel passage in the carb.
Jul 07, 2014 | Weed Eater Featherlite Fl20 Lawn Edgers
Fuel line diagram for craftsman 32cc weedwacker weed eater
digrama for weed wacker 32cc modelo 368791156
Aug 23, 2012 | Garden
I have the 32cc Craftsman weed eater, when I turn it on, it turns off after 2 seconds unless I have my finger on the trigger. As soon as I let go, it turns off
Hi David
My first target would be the Low Idle adjustment.
On or around the air intake, look for two holes or two screws. They should be labeled 'H' and 'L' (for High and Low).
Get a screwdriver and back the 'L' screw off in quarter turn increments, checking the idle between each adjustment. When it keeps running on it's own, test the trigger.
At full power is should not bog or stumble. Adjust accordingly.
That should do it.
Best regards
Mike
Jul 12, 2010 | Craftsman Garden
I have a Craftsman 32cc weed trimmer, can't give gas, it stalls
Usually the diaphram is wore out. It is a relatively inexpensive part. Does it run better with a little choke? If the answer is yes chances are it's the diaphram. Also sometimes the adjustment screws can move. There are two, one for low speed, and one for high. With the engine warmed up make small movements on the screws (some are marked low, and high) in, and out adjust til the engine runs at its optimum.
Hope this helps!
May 04, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel hoses routed wrong on weed eater fuel tank
Apr 04, 2009 | Garden
Garden Logo
2,212 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
