Question about Grilling
User manual for great outdoors smokey mountain propane smoker
  • 2 more comments
  • Anonymous Feb 17, 2008
    smoker will not heat up past 250 .....unsure why
  • firemandave1 Dec 17, 2008
    Temp will not rise. Think it might be regulator. Need to know how to replace hose/regulator also, not sure how clamps work. Thanks.
  • Anonymous Feb 25, 2009
    I have the same problem too. The label on the front says to check the line (?) - refer to owners manual" I got it used so?
    JIm
  • Anonymous Mar 15, 2009
    need user manual for smoky mountain serues 3605g lp gas smoker
3 Suggested Answers
SOURCE: Need manual for Great Outdoors Gas Smoker
You can look under Landmann USA. They make the smokers now.
Posted on Sep 13, 2009
  • 4 Answers
SOURCE: I need a manual for
Yes I do, what do you need to know?
contact me marite55@mail.pf
Posted on Jun 08, 2009
HOW DO i CONVERT A CHARCOAL SMOKER TO A LP sMOKER
My advice would be: go to Landsman Smokey Mountain/search parts lists for their propane smoker/order the proper burner, mounts, regulator and hose. Assemble according to the Parts diagram. install a wood chip box. Happy Smoking.
Dec 15, 2014 | Landmann Smoky Mountain Two Drawer Easy...
How to fix a leak on a Great Outdoor Smokey Mountain propane smoker?
Goop will seal the hole and it will work (I use it for many fixes) the problem is that where there is a hole the metal is probably corroding and there is another spot that will go soon. If you can't find a direct replacement, have someone make one for you (unless you can do it yourself) until then get a tube of Goop (household) patch the hole and let it dry overnight.
Jun 22, 2012 | Grilling
Need a owners manual for the 34" propane smoker great outdoors smokey mountain smoker
The truth is that the user manual/instruction for your propane smoker is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of this unit via phone or e-mail and request for the instruction/user manual from them. They might give it to you or direct you to a dealer where you can get the instruction/user manual.
This is the best you can do to get the instruction/user manual you are requesting for. Go to the propane smoker's website, check "Contact Us" and you would see their e-mail and phone number.
Below are some instructions that may help you with your propane smoker;
Set Up the Tank
The first thing to do in using your propane smoker is to connect the propane tank to the smoker. Open its valve by turning it in a clockwise direction. Next, you need to locate the wood chip box. Fill the box with any wood that you prefer, like hickory, mesquite or oak.
The wood chips when lit produce a smoky flavor that is absorbed by the food in the propane smoker. Each type of wood produces its own distinct flavor. Remember to soak the wood chips for at least an hour before using them so that they do not burn quickly. Soaking the wood chips also helps to create more smoke inside the propane smoker.
Fill the Water Box
After filling the wood chip box, you need to fill up the water box of the propane smoker. It is usually located right above the wood chip box. You can fill the water box with water or with sand. You can leave it empty, but it is best filled with water because the evaporation during the cooking process keeps the food from getting dry and tough.
When cooking with a propane smoker, moisture is important. Keep adding water when the level in the box is low. To add more flavor to your food, you can also add spices and seasonings to the water.
Cooking Time
The propane smoker is almost ready. All that is left to do is turn on the smoker and adjust the temperature. Most models have a rotary dial that controls the level of temperature in the smoker. The temperature depends on the type of food that will be cooked.
You should use a higher temperature for thick slices of meat and a lower temperature for thin slices of meat or for vegetables. Once you see smoke coming out of the smoker, it is time to put in your meat or vegetables. Cooking time depends on the kind of food being cooked and the thickness of the meat being smoked.
I hope this helps.
Good luck.
Mar 10, 2011 | Grilling
How do I use it?
I've been smoking for over 10 years and basically use the Weber Smokey Mountain. You need lots of practice to make good "Que" but once you get the basics under your belt you too can make some awesome barbecue. I can guide you to the Virtual Weber Smokey Mountain site to get the basics. Google " Virtual Bullet" Enjoy...Hank
May 19, 2010 | Char-Broil Charcoal Water Smoker 4654301
Have a 2003 Smokey Mountain Series 36'' gas smoker and looking for part AZ001163 Wood Chip box and AZ001111 Water Bowl. Any idea how I can purchase these. I live in Wasilla, Alaska phone number...
For questions regarding replacement parts or service inquiries, please contact weber customer service at 1-800-446-1071 or email Support@WeberStephen.com
Apr 20, 2017 | Sport & Outdoor - Others
I need a regulator for a Great Outdoors - Smoker
gas regulator are gas regulators so go to a hard ware shop that sells BBQ /outdoor cooker equipment,
take yours along as a sample and get a new unit
Apr 25, 2017 | Grilling
I need the user manual for george foreman grill model #GGR62
i need a owners manual for a smoky mountain smoker propane
Jul 11, 2009 | George Foreman GGR62 Grill
I have a Great Outdoor smoker that won't get hot.
I had the same problem with mine. I took the burner assembly at the knob apart and cleaned it and that worked for me. The grease from the meat dripped down on the gas orifice and hardened reduced the amount of gas being jetted to the burner. Hope this helps
May 31, 2009 | Great Outdoors 3600G
Company went out of business.
Dec 17, 2008 | Grilling
Grilling Logo
2,957 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
