Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool LSN1000KTO Quiet Wash II (Agitate but nothing else.)
My washer will agitate but won't drain, rinse or spin. Just sits full of water. Only sound, is the timer ticking.
    Sergeant:
    Champion:
  • 219 Answers
You have a faulty lid switch you will need to remove the cabnet and replace.To open you will need to remove the star screws off the rear consel corners and pull control panel up and over.If there is no screws you will need to use a puddy knife and push the front corners between the top and consel there are 2 clips ther as you push the knife lift at the same time on the consel.Then there are 2 brass clips stick a flat screw driver in and pry up they should pop off..Then remove the wire harness from lid switch.The lid switch will be under the cabnet or on the toprear left corner.to take the top lide switch remove the 5/16 screw and lift the lid then switch will come off.install new on if older the switch hase 2 srews around the inside lid area where the stricker pushes down then remove screw under the cabnet as well.hope i helpes is give me a fixya thank you so much :)
Posted on May 13, 2009
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like a broken coupling.
it probably don't agitate either.
Oct 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
287 people viewed this question
Dan Webster
Dan Webster
Sal De
