Question about Vacuums
Hoover steam vac
I have a hoover steam vac model number f5809.  I let my mother borrow it and when it wasn't working properly, she pulled a white hose out of the bottom of it.  I have no idea where it belongs.  Now it seems the cleaner is coming out, but it is not sucking it back into the tank.  Does anyone have any idea where this hose belongs???
Re: hoover steam vac
Usually on the hoover steamvacs you have to take the gearbox apart and grease it up[
Posted on Jun 27, 2008
  • 1,673 Answers
Here is a picture, maybe you can trace where the tubes go, I am sure you will have to take the top cover off.
Posted on Feb 14, 2008
0 characters
3 Points
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
No suction in new Hoover Steam Vacs hopefully this helps
May 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model # f7441-980
Hoover steam vac
Posted by beverlyarm on Mar 21, 2008
XThis Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request By reddevil6, posted on May 01, 2008 What is your problem? Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You may have a bad water pump, bad gasket, the water release valve could be broken, or the water tank is not sitting on the opening properly or the trigger assm is not closing properly. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Mar 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
had my steamvac spinscrub for 3 days now. it will not **** up why?
Jan 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
163 people viewed this question
Top Vacuums Experts
Roger Potts
Are you a Vacuum Expert? Answer questions, earn points and help others
