I can see the picture but it is real dark. was told it was the back light is this true and how hard or much is it to fix?
  • swebb33 May 13, 2009
    its not that something more was told the back light went out. was wandering if it is hard to fix or how much it would cost to fix?
    i was told 300 - 400 to fix it. does that sound right?
    Problem Solver:
  • 6 Answers
You can go into the setup menue and lighten it up
Posted on May 13, 2009
  • pboyle608 May 13, 2009
    if it truly is the back light check and see if it is under warranty cause it is expensive
    Just about for the piece but might be more for the labor
How to fix smart tv with sound and very dark picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 24, 2015 | Televison & Video
Dark picture even after new lamp was installed
Reseat all connectors that you removed then try once more. its a back light problem reseat back light once more.
Oct 15, 2012 | Hitachi 50VG825 50 in. LCD HDTV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Dark Picture
Your backlight transformer has failed, this is not a simple fix and requires the replacement or one or more of the boards in the back of your tv.
Mar 07, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
I think my color tubing is out it is sooo dark you can barely see
Not necessarily so, it may not even be the tube but a fuse that costs a few dollars. Get a proper investigation and quote
Aug 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Pictures very dark, Brightness all the way up. Contrast does not adjust
I have the same problem. I was able to temorarily fix the issue by taking the back cover off and blowing all of the dust out. But this only worked for two days. Now the problem is back. Did you fix the issue with your tv? Thanks.
May 28, 2009 | Hitachi 46F500 46" Rear Projection...
LCD screen is very dark, Pictures taken are underexposed
If the pictures show up normal on the computer then the back light for the LCD is going bad.
Apr 05, 2009 | Canon PowerShot A640 Digital Camera
Model # WD-62525 lost picture
really hard fix. but its like 350 to send it off to the repair center in cali.
Mar 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Camera is dark
when i go to take a picture or a video it comes out dark. you can't hardly see the person i took the
picture too. It's very fustrating not knowing how to fix the matter. all those buttons are not helpng at all. Can i get any suggestions on how i can make the pictures come out brighter?
Nov 06, 2008 | DXG Technology DXG-305V Digital Camera
Televison & Video Logo
Top Televison & Video Experts
