Question about LG LRFC25750 Refrigerator French Door
Fast clicking noise when compressor is on.
I have a LRFC25750TT refrigerator that just recently started making sounds like something is hitting a fan? If I open the door, it stops, but as soon as I close it, I hear the clicking ramp up to speed, and then stay constant. Any suggestions?
  • Samuel Charles Spriggs May 11, 2010
    Are we talking 24 hours a day as long as the door is closed?
    President:
  • 1,136 Answers
Hi, Can you see any frost builring up on the rear panel of the freezer. Most of the time the evaporator is hitting something, it's frost. If it it frost, you your automatic defrost cycle is not working properly. If there is no sign of frost, it is possible a little ice has formed around the fan or even a wire has fell near the fan blade. Best way is to remove the rear panel in all these possibilties and see what is happeningm
I hope this has helped you. If I can be of more assistance, please let me know.
Thanks
Vic
Posted on May 13, 2009
Does not putout cold air and makes a clicking noise
if you tilted it and plugged it up emediately after moving the internals in compressor are probably broken' also if floor is uneven where it is now condenser fan could be hitting a cover which would cause click fan would not turn rite and would cause it not to cool.
Apr 18, 2012 | Maytag Refrigerators
Lg lrfc25750tt refrigerator, have to hit compressor to make it work. At first, the compreesor tried to come on with a loud hum, then would shutoff in about 10 seconds, did that about at least 4 times in 2...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | LG LRFC25750 Refrigerator French Door
My whirlpool side by side refrigerator just started making this loud noise that sounds like either what an air compressor would sound like or a lawnmower. The model is ED5FHE
There are two fans running on a side by side, one is behind the back freezer panel on the side of the freezer side( if it is iced up the fan blade could be hitting ice) May be a defrost problem......
(this fan circulates air from the freezer side to the refrigerator side, as the air is pulled through the coils heat is removed)
The second fan is in the back, you have to pull out unit and remove lower back panel to listen and or look to see if condenser cooling fan is running quiet or the compressor right next to it. Could be this fan blade is hitting something or a bearing going out.......
If the compressor is making the noise you are probably not going to repair it.....
Lastly on some there is a defrost timer motor usually found by the thermostat but not always that could be making noise(least likely) May have a adaptive defrost control board, not sure.....
Hope this helps........
Feb 08, 2011 | Refrigerators
My fridgidaire makes an odd sound in the back as if a fan blade is hitting something. It happens periodically, not continuous. What can I try to fix this? Is it as simple as removing a cover to clean...
The bearings are going bad on the fan motor and that lets the blades move too much and they hit...you will need to replace the fan motor.
If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
Loud buzzing noise coming from the freezer motor like something is stuck or hitting...possibly a fan...possibly the compressor...
Sounds like pipe vibration, you will need to take a cover off if there is one to get to the compressor. Check to make sure no pipes are rubbing against each other first, you can bend them apart carefullt, watch out for a hot pipe from the compressor. Also check to see if there is a cooling fan for the compressor, make sure all fittings are tight etc, If the noise is still there call a refrigeration technician.
Regs,
Hawk
Jan 16, 2010 | Kenmore 54622 / 54624 Side by Side...
My refrigerator just recently started making a loud sound almost like a fan was breaking. Is my refrigerator breaking or can I fix this?
If this sound is when the compressor is cutting on or off it's the internal parts of the compressor. It can work like this till it brakes. There is no way to fix it without replacing the compressor. If you can put up with the noise just wait. Or it could be the fan behind the back cover inside the freezer hitting somthing like ice build up. Try to pinpoint the area the noise comes from.
Sep 01, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
MY ROPER REFRIDGERATOR IS MAKING A LOUD NOISE. POSSIBLY THE FAN OR COMPRESSOR? WHAT CAN I DO TO QUIET IT DOWN?
First find the area the noise is coming from. Does it sound like a fan hitting something? Or is the compressor making the noise? Has dust collected in the condenser coil area that has cause air restriction ? I a paper shroud that is mounted near the fan come loose and striking the fan? Has the noise affected the performance of the refrigerator? Let me know and I will be able to help you solve this.If you find the problem please remember to unplug the refrigerator before putting your hand in an area that could cut or shock you!
Click link below to get more problem solving answers. And if I can help let me know, Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Feb 01, 2009 | Refrigerators
GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Apr 08, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
LG LRFC25750 Refrigerator French Door Logo
386 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
