Question about Epson Office Equipment & Supplies
Interface first i don`t know what interface this printer use
  • ericcompusa May 13, 2009
    THANK YOU, I RESEARCH AND I FIND THE SOLUTION, THE PRINTER IS A MEDICAL DEVICE, IT DON'T WORK WITH THAT KIND OF INTERFACE, BUT THANKS ANYWAY
  • 315 Answers
Most printers use a USB type A Male to USB type B male cable.
Usually advertised as USB A-B cable.
One end is a normal USB flat shape and the USB printer end is a square shape.
Pic below:
http://www.amazon.com/gp/product/images/B000UWIGGS/sr=8-7/qid=1242174027/ref=dp_image_0?ie=UTF8&n=1064954&s=office-products&qid=1242174027&sr=8-7
Posted on May 13, 2009
Brother mfc9320cw goes to sleep and won't wake up without turning printer off and on again
I had the same problem
on my brother MFC-9320CW
I set it up to work over wifi and it worked well for months then i started having issues one day (showing offline)
i had to restart the printer all the time to be able to print again (showing as Online).
but after 10 - 15 mins it lost connection again and I could not see it on network (PING IP)
I couldn't even web-interface to the printer in the browser using its IP address (** see below)
It appeared to point at a printer problem
I know this may seem strange but eventually my investigation came to finding that it was a router problem - well my router anyway.
It doesn't make sense i know - but it was definitely a bizarre router problem in my case.
After that i was able to web-interface to the printer
I RECOMMEND YOU DO THIS:-
1. turn off your printer
2. restart your router
3. wait 2 mins
4 restart your printer
IF YOU FEEL CONFIDENT TO DO EXTRA TECHNICAL/NETWORK CHECKS
Also allows you to manage things at your machine
5. ** find out the IP address of the printer - either on the printer itself - menu>network>IP
ive setup my printer to be static IP so i always know what it is
OR If you know how to get into the control panel (web-interface) of your router then it will show active connections and IP addresses of equipment - including your brother printer
6. i use the web-interface as it immediately shows me if i have a dropped wifi problem--If the printers control panel is avalible in my browser then all is fine
Nov 06, 2012 | Brother MFC9320CW All-In-One Printer
Can not discover HP Laserjet M4345 with HP Web Jetadmin
Do you have internet access in you system, if not you cannot access to jetadmin, check internet permissions, I don't think so its printer side problem, take help from system administrator to solve this issue..
Feb 03, 2012 | HP LaserJet M4345 MultiFunction Printer
Hp T-610 gives an error code of 08:11. Can I get some help.
No comunication between the Front Panel and the Main PCA. If you don't know what you are doing, Get a printer tech to check it out. If you do know what you are doing....
Corrective Action: Try the following: 1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer. 2 Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel. 3 Check that the connections between the Formatter and the Main PCA are not damaged and are correctly connected. 4 If the System Error continues, replace the Formatter. 5 If the System Error continues, replace the Main PCA.
Aug 15, 2011 | HP Designjet T1100ps Printer
I need drivers Eltron Zebra P310CM for Windows 7
Hi I solve this problem with a program called CardFive this program provides several drivers inside when you install it in Windows 7. I install CardFive 6.3. Note. this program don´t install a printer driver in Devices and Printers in Windows 7, only provides you a interface to print cards with your Eltron p310 and you can choose other printer models discontinued. My printer interface is parallel and works in Windows 7 With CardFive 6.3 pro.
Jan 14, 2011 | Zebra Eltron P310 Thermal Printer
Have a Samsung desktop - how do I attach printer cable?
It really depends on the specific printer interface you have!
Newer printers can be attached to a Desktop or Notebook via the USB interface (small connector as for mouse).
Older printers, and 'commerciall' high speed printers, have a 'parallel' printer interface (large connector - LPT port) that will connect to a desktop (or higher end laptop) with a parallel (LPT) printer port. If you need a LPT connection, a USB to LPT converter can be used ... but a newer USB connected printer may be a cheaper alternative in this case!
Hope it helps let me know how you go.
Dec 13, 2010 | Samsung NC10-14GW Notebook
I have an Epson 2200 and the Light black ink light is on even thought I have a new cartridge in there. This is the second cartridge I've tried. Same thing. Any suggestions?
this means that your printer wast pad is full this is how you can reset your printer
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
  10. make sure you have got new wast pads in
Dec 04, 2008 | Epson Stylus 2200 InkJet Photo Printer
I HAVE SOMEHOW WHEN TRYING TO TO PRINT HAVE BUILT UP IN THE STORED DOCUMENTS ABOUT 100 DOCUMENTS AND DON,T KNOW HOW TO CLEAR THEM AND SO CAN,T PRINT ANYTHING ELSE CAN YOU HELP PLEASE
put the printer off for some minutes ,remove the printer interface wire from the cpu,now go to start on your desktop & select setting ,then printer &faxes .rightclick that printer icon &select cancle all documents. by now ur pilled up documents must have clear if it remains and prove abortive, restart the cpu & go thru this procedures again it will clear the whole documents. then reconets your printer &put it on,put paper & allow it to get read on its own. then rightclick &select properties select print test page.by now you should get testprint page & your printer is again ready for use.
thanks u can let know your result for further assistance.
Oct 05, 2008 | Lexmark Office Equipment & Supplies
PagePro 1350W communication pops in and out
If you are using the USB interface, try switching to Parallel port instead. I had nothing but problem with USB and they all went away when using the Parallel interface.
Sep 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
OKI ML280 serial card installation
I believe on the top of the printer towards the back is a panel with a single screw. Under here are dip switches to set the printer.
Jun 18, 2006 | OKI (09002353) Serial Adapter
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
