Question about Troy Bilt 5.5hp Self Propelled Mower
I OWN A 2006 TROY BUILT HORSE 23HP. THE PROBLEM IS THE ENGINE IS HARD TO CRANK. I REPLACED THE STARTER AND BATTERY. COME TO FIND OUT THE ONLY WAY I CAN GET IT TO CRANK IS TO TAKE THE SPARK PLUGS OUT. ITS LIKE THE COMPRESSION IS KEEPING IT FROM CRANKING.
  • Samuel Charles Spriggs May 11, 2010
    It still sounds like the battery and/or starter.
    Did you super clean all the electrical connections: battery, starter, alternator, etc.?,
    What does the charge read on your battery right now? Do you have a voltmeter to check it?
    President:
  • 957 Answers
You either have a problem with the wiring and its not allowing the voltage to flow freely to the start or there is some type of internal engine failure that is causing the valves to stay closed.
Posted on May 13, 2009
Mower turns just a couple times then stops. Could it be the starter (725cc 23hp Kohler engine, troy build hourse)
sounds like the valves are out of adjustment. not letting the compression stroke release on time.
Apr 15, 2017 | Troy Garden
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
I have a troy Built Bronco ridering tractor with a Kolher courage 18 597cc motor. When I go to srtart it turns over slow almost like a vapor lock, I have replaced the battery and has full charge. I h
The engine will have a valve lifter on the cam shaft to reduve the compression on start up if the valve clerances are too wide the lift will not work making it very slow to crank.
Sep 12, 2012 | Troy Garden
My lawn mower is trying to turn over but won't completely. we have replaced the starter, battery, and spark plug. why will this not crank and turn over?
It probably has a faulty starter solenoid which won't allow full amperage to the starter. Also the valve clearances need checking because if they are too loose the built in decompressor will not work and allow the engine to crank over. Regards Phil
Apr 15, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I am looking for a wireing diagram for a soloenoid part # 725-142A on a Troy-Bilt 13AP60TP766 Horse (2006)
here is web site for parts
http://www.partstree.com/parts/?lc=troy_bilt&mn=13AP60TP766+Horse+%282006%29
http://www.outdoordistributors.com/MTD/MTDpartslists.html
enter model numbers and select manual download
basically heavy red wire from battery goes to 1 heavy termial on soleniod and the other red lead that is connected to starter motor goes to to the other heavy solenoid terminal
their should be a wire that comes from main switch ( from start mode )
that connects to small solenoid tab and the other tab if it has one will be for a earth ground wire
12 vlt comes from start switch ( start mode ) and energises solenoid
pulls contactor together to make contact accross heavy terminals and sends volltage to starter motor , s/motor turns over engine
cheers
Aug 06, 2010 | Troy Garden
Have a 9 horse troy built 33in walk behind mower,I want to replace the engine with a another briggs a 15 horse, but it has some extra wires to the carburater bowl and I wnat to make sure where they go and...
The wire to the carb bowl is a fuel shut-off solenoid. Needs battery voltage applied while the engine is starting/running. Your ignition switch will need a 'load' connection (battery voltage when 'ON' or 'START', off otherwise.
If your ignition switch is not suitable, you will have to rig something.
Jun 23, 2010 | Garden
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a older troy-built tiller (horse), belts slip under load
Remove the Belt, take it to an a Auto parts store and buy a smaller one, the replacement engine may not be exactly as the old one was
Apr 18, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
178 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
