Will fill and drain but won't spin without assistance.
Kenmore washing machine 417 model. Will fill with water and drain. But will not spin. We took the top of and can sometimes get it to kick in by movng the drum. Once final spin gets going it will finish on its own, once have jiggled it. Any suggestions?
  • 77 Answers
The safety switch could be broken or loose. This switch tells the machine that the lid is closed so that it only spins with it closed.
Posted on May 13, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
417-44052400 Fills with water, washes, drains/spins then comes to a stop. If I did the diagnostics right it indicates E11? Anybody else have this problem?
e11 is a water problem filling to slow,you could have a problem with your cold water fill line,clogged sediment in the valve or something like that,when it goes into rinse the machine uses cold water so the clothes won't wrinkle and it sounds like it's filling to slow.
Nov 26, 2011 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Aug 11, 2009 | Kenmore 43042 Front Load Washer
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Front load kenmore washer model 417 will not enter any wash cycle. It will do the rinse and spin cycle but not a wash
will it fill with water? if not listen by the water hose when you press start to wash and see if you hear a faint buzz/humming sound. If so you need to replace the water inlet valve. cheers
Mar 25, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
