To reconnect the 2 jumper wires in my Acer internal wifi card.
I disconnected the internal wi fi card in an Acer 5920 laptop. I have 2 wires to reconnect to it to finish. Question is where do they attach to: post number 1, post number 3 or post number 2? It's labled in that order on the card. I have a black wire and a white wire to reconnect.
Help Me OBee Wahn Kanobee, You're My Only Hope!
Thanks, Paul
  • psgetti May 13, 2009
    My wi -fi card only has a No.1 No.3 No.2 . Nothing such as main or auxiliary is written on it. Thanks for trying.
    PsGet
  • 115 Answers
On the internal wifi card u might find a slot marked as main and auxillary.the white cable goes to the main slot and the black cable goes to the auxillaryu slot,,best of luck
Posted on May 13, 2009
  • Abhisek Das May 13, 2009
    try 1 with white then and 2 with black..that shud work..the extra slot is for N cards.best of luck again.i will keep on trying
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
When a technician opened my laptop acer aspire 3000 we saw two disconnected wires and he doesn't have the referrence to connect the wi fi switch whenever i turn on the switch for the wifi it doesn't turn...
hi i think i understand your question
the disconnected wires you talk about is one black and one grey
if you could let me know i will try and assist you
Jul 05, 2010 | Acer Aspire 3000 Notebook
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
My Acer laptop wireless not working. It was
first network setup wizard then u try the internet through wireless
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
Insirion E1505: Missing Wi-Fi device
I would not open up one of these animals if I could avoid it! Go to the bios, "Disable" the Wi-Fi. Re-boot and ensure NO Wi-fi AT ALL in "Device Manger". If you have the software for the Wi-fi (May be on the System disk that came with the machine) go to "Remove Programs" and take out any software for this device. Shut down completely. Leave for a couple of mins. Re-start and go into bios. Re-enable Wi-Fi and re-boot. re-install software IF requested. Good Luck! Ian.
Sep 28, 2009 | Computers & Internet
I have an Acer aspire 5610z Just acquired a Verizon MIFI2200 53CF Secure Ability to network 5 wireless computers Was able to configure below not problem IBM T60 Compaq Presario Not the case with...
This method will hard reset the wireless drivers back to default settings, but before you perform this remove power from the modem and router for 2 minutes reconnect power and wait another 2 minutes for them to settle down.
Go to your laptop, right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Aug 03, 2009 | Acer Computers & Internet
I am unable to install my wi fi
it really depends on what wi-fi card you have, the best way to check is to go to control panel, system, device manager, check for the yellow question mark by wireless cards, then it should tell you what wireless card is in there so you can obtain drivers.
Or check your laptop manufactures website, drivers are 90% of the time available on their, have you also checkd that your router is wireless enabled and that the secuirty keys and wireless settings match up?#
cheers
Feb 28, 2009 | Acer Aspire 5920-6727 Notebook
Problem wifi acer 4720Z
Remove on bottom covering Wi-Fi card. Unseat and Re-seat Wi-Fi Card.
Feb 25, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
