Question about Garden
Starter cord loose on Bolens 4.5 HP lawn mower
When I pull the cord to start the engine it is real loose. It is not starting the engine.
    President:
  • 1,489 Answers
Need to remove the pull cord assembly. Something is amiss in there. If you don't want to attempt it, I'd take it to a shop.
Posted on May 13, 2009
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
On my Baumr-AG Tornado 650EX 4-stroke lawn mower my starter cord will not retract
There is a spring under the dog ear plate it's probably broke there's a hook on one in of the spring that hooks on to the housing and and the others end hooks to the starter pull it's self take bolt out of center of pull start and take a look be easy the spring sometime likes to fly out its not a typical spring per say it's a coil spring wound up
Jan 06, 2015 | Garden
Starter cord won't pull all the way to start engine. Engine 300 series 4.50 Lawn mower
Remove spark plug pull cord. This will release compression blow out cylinder. Replace spark plug try cord.
Aug 03, 2013 | Garden
Broken spring in recoil starter on lawn mower
While I have not done this on newer model lawn mowers, I have replaced recoil springs in the past. Here's what I did: First you need to pull the spark plug wire off so the engine will not start. Then block the flywheel with a piece of wood to keep it from turning. Then, using another piece of wood such as a short (6-8 inch) hardwood dowel placed against the ears of the recoil drive, and drive it in a reverse direction (clockwise) with a hammer to knock it loose. It may take several sharp blows to break it loose. The recoil drive is reverse threaded to keep it from coming loose when the engine is running. Once the drive is loose, remove it to get access to the recoil spring which must be replaced if it is broken. With a new spring in place, rethread the recoil drive counter clockwise until it is finger tight. Then, tighten it down with one sharp blow against the wooden dowel.
Jul 10, 2013 | Garden
Lawn mower recoil spring
Remove mounting nuts, pry recoil off fly wheel. Purchase new recoil assembly at mower repair store.
Why is my Tecumseh 6.5 hp engine hard to start after taking blade off.?
When you tilt the mower too much oil will mix with gas. Try taking out the spark plug and cleaning it good in case some oil got on it. If this don't solve it, drain the gas and refill with fresh gas in case oil mixed with it when you tilted the mower.
Aug 04, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
I was mowing the lawn, and I ran over a dirt *****. Now the engine will not start. It also sounds like something is loose inside. I hear a few clunking sounds when I pull the cord. Do I need to take...
Yoy can try tightening the blade bolt. i know it sounds funny but if the blade bolt is loose (or even alittle loose) the blade balance throws off the engine balance and can cause it to
1 not start
2 make loud clunking noises when trying to start
3 make a real racket if it does start
try flipping the lawn mower over and just tighten the bolt that holds the blade in place.
That should fix your problem.
Please dont forget to rate my answers
Thank you
Jun 17, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
I have a TROY-BILT model 566 Smart Touch mulching mower. The starter pull cord (for lack of a better term) did not rewind when I tried to start the mower last weekend. I rewound the cord once by hand and...
sometimes these are shot dogs; these are what come and grap the engine and the cord is loose for about an inch or two and then you feel restance from the engine commpresion to start these DOGS are plastic and cheap
Apr 10, 2010 | Troy Garden
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
Garden Logo
595 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
