Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Freezer not working
The freezer is not freezing and everything in the freezer is melting. There is a red light that says "filter". I don't know where the filter is and why would the filter make the freezer stop working?
    Sergeant:
    Champion:
  • 214 Answers
Please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
Posted on May 14, 2009
GE fridge modle#GSH25JFRFWW serial# MH236895. My freezer will stop freezing for a while. Ice will start melting down the door. Then freezer will freeze again leaving ice cycles down the door. Also my water...
Yes this is complicated for me.
But in case my method works for you here it is:
Turn off the freezer and empty it. Depends on the time of the year where to put the things you take out of the freezer.
Put boiling water in cooking pots, the pots inside the freezer and have a lot of towels handy when the melting begins.
When all the "frost" has melted and still no power on the freezer, clean it well and take a knitting needle and try to put it in the hole in the middle of the waterline. Usually some muck comes out. Leave it like that and put everything that you are going to keep,in the freezer again.
The power on and hope for the best, which usually happens.
kolbrun
Apr 09, 2012 | GE Refrigerators
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
I have a roper model RT14ZKXDWOO and the freezer is working fine but the refrig is warm. I took the panel off the back of the freezer and it is full of ice. What should i do next? and is there a diagram...
Hi,maybe I can shed a little light.I don`t know where the defrost timer is,but I would melt the ice with a hair dryer and real warm water(it will make a mess so be ready).There will be a drain inside of the freezer compartment,on the inside.Some how the rear panel inside the freezer compartment comes out.You may have to take apart the whole inside of the freezer compartment just to remove this rear panel.But when you do look for ice build up on bottom of freezing unit,and the rearof the freezer compartment.Melt this ice the same way earlier described.You will find a drain that starts inside the bottom-rear of the freezer compartment.This drain goes all the way down to the bottom of the fridge.You will find a very shallow drip pan under the fridge.This pan will most of the time only receive a little amount of water at a time and evaporates quickly.Now while you thaw this drain,water will start draining threw the drain,if it is not stoped up with food particles and such.This would be a good tome to blow threw this ine from the bottom where it drains into the pan underneth the fridge.Then blow threw it at the top in the freezer compartment.You can use a air tank with a blow gun.Be sure to pour water threw and down this drain to wash out all particles left behind.Clean the freezer compartment out good(the particles of food and such) and reassemble the freezing unit.plug fridge back up and set the freezer control to a respectfull setting(not the coldest and not real cold)and set the frideration to a decent setting for food preservation. Let the fridge and freezer run 12 to 24 hours to see if your problem comes back,and then time will tell if your defrost timer is bad,or is working like it should.When the drain clogs,it starts freezing away from the defrost elements and continues freezing the blocked water untill it overtakes the coils .The defrost and the timer don`t stay on long enough,or hot enough to overcome the ice.This is the reason you should try this solution first.If I can help you anymore,let me know roniecon@gmail.com /let me know how it turns out
Jul 12, 2009 | Refrigerators
Freezer not freezing
Here is a complete service and repair manual for your refrigerator. It has everything you will need to know about this fridge. The manual has how to run all the diagnostics to determine which parts may have failled.
Good Luck,
Thanks
Jan 03, 2009 | Samsung RS2630WW Side by Side Refrigerator
Freezer freezes at top but not at bottom
  1. first make sure the fan is coming on in the freezer. if it is not working then the fan motor may be bad or obstructed.
  2. then Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | GE ZIS420NR Side by Side Refrigerator
Refridgerator/Freezer will not get cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
Mike
Jul 21, 2008 | Refrigerators
Ge profile refrigerator
  • possible causes:
Jul 05, 2008 | Refrigerators
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
  • possible causes:
Jul 04, 2008 | Magic Chef Refrigerators
Freezer is only cool, everything melting
  • possible causes:
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer not freezing, fridge section not cooling
the problem you have sounds like the defrost heater is not being activated causing the evaporator to choke up with ice which will therfore restrict the airflow through the cabinet,
to resolve this problem you are best to defrost the unit and replace the thermal fuse for the heater' and the defrost sensor, both these parts are located behind the evaporator cover inside the freezer.
hope this is of help murdozzz2
Dec 08, 2007 | GE GSS25SGSSS Stainless Steel Side by Side...
Refrigerators Logo
142 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
