Question about Samsung DLP HL-P5663W 56" TV
What does the color wheel "plug in" to?
Re: Samsung HLN507WX The color wheel has a copper ribbon and 2 white/1 blue wire that plugs into something. My problem: whatever that blue/white wire plugs into is broken. How "screwed" am I? thank you
The white clip that the 2 white/1 blue wire plugs into breaks when you remove the the wire. This should not be a problem as the wire should still fit snug when you plug back in.
Posted on May 18, 2009
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
Tip
Repair job continued
7. Locate the color wheel cover. It’s got a small green circuit board on top of it with a black/blue wires connected to it. Remove that plug. Also, and this is the trickiest part, remove the two cables coming from the color wheel. One is a copper-colored ribbon cable. That will just slide out easily. The other is a cable with two white and one blue wire. This one is tricky to remove, so you’ll need to ease it out. I pried it out with a jeweler’s screwdriver. DO NOT just pull on the wires.
Note: A reader made the following excellent suggestion to avoid breaking the white connector on the end of the blue/white/white wire:
Having replaced quite a few of these colorwheels as a Samsung service tech, I have found that you do not have to remove the blue/white wire from the DMD board (avoiding the risk of damage to the optical engine) There is enough slack in the wire to route it around the cover when removing it. You can then unplug the wire from the old colorwheel and plug it in the new one (the plastic tab will break off the old connector when you go to remove it,but it will still fit snugly on the new colorwheel) Using this method I have had no problems reusing the old connecting cable
Color wheel cover view from top-down. This part has three screws and slides straight up.
color-wheel-wires.jpg 8. Unscrew the color wheel cover. There are three screws holding it in place. One to the rear of the set, and two in front. The one to the rear is tucked way in, so I just unscrewed them and carefully left them in place and pulled them out with the cover. Slide the cover straight up, exposing the color wheel. As you do, note where the color wheel wires go — out the gap in the front.
cover-removal.jpg 9. Remove the bad color wheel. The color wheel is held in place with three screws. Remove the screws and the color wheel. The color wheel may be stuck in place with the foam tape, but that’ll give with a small tug. To remove the wheel cleanly, I lifted the front edge and slid it toward the front.
color-wheel.jpg 10. Insert the new colorwheel. It can be tricky to do this without touching the wheel, or bumping the wheel into the case. (This is where you need the nerves of steel). Once you get the proper angle, it will slide into place. Don’t force it — remember, this thing needs to spin at 9000 RPM, it’s probably pretty sensitive. At first, I tried to put it in place with the screws already in the holes. This didn’t allow me to slide it in properly. Lesson learned: put it in without the screws and then hold the screws in place with tweezers, if necessary.
11. Put the color wheel cover back on with the wires out the space facing the front of the case. Make sure the wires reach their destinations, and screw in the cover. Three screws. Attach the three connectors. The metal contacts on the ribbon cable face the rear.
12. Put all the guts back in place. Slide the center unit back in. Without touching the projector lens, open up the slice in the foam so it wraps around the projector lens, and slide it in the rest of the way. The center unit can only go in on it’s track, so again, don’t force anything. Connect the two wires you removed on the left side. They should only go in one way. Did I mention don’t force anything? Screw the sensor switch onto the bracket on the right.
13. Put the power cable in it’s slot. Just the way you noted on the way out.
14. Slide the left PC board and panel back in place. There are two screws that hold it in place that you screw in now, the rest hold on the access panel.
15. Put the projector lamp back in place and screw it into place. I forgot to do this both times.
16. Put the access panel back on and screw it in (14 screws)
17. Plug in the television, say a prayer, and turn it on.
on Mar 30, 2008 | Samsung DLP HL-P5663W 56" TV
My hl-p5063w had a bad color wheel so I replaced it. Now the tv will not power on, the
There are a few common pitfalls to avoid when replacing the wheel.
1. There are two plugs from the wheel that connect nearby. One is a conventional plug you have to be careful with as easy to break the wires.
2. The other is a ribbon cable--it only has on the flat end contacts on one side---it is quite easy to put it in BACKWARDS where the contacts make no connection.
There can be another issue if you get the set up and running--color will look odd--blue seems wrong etc---that will not stop set from coming on and is a jumper that needs to be removed.
The instructions for most of these wheels do not mention any of this so.............
SD TECH
Jun 01, 2012 | Samsung Televison & Video
My samsung dlp tv model#hln617w keeps turning off. Only stays on for 2 minutes. I replaced fan #2. Thunking that was the problem.
Why did you replace the fan was it noisey and did that cure the noise. These sets commonly have problems with color wheels-do you get motor noise at startup?
Sep 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Color wheel plugs into what?
Okay what you can do is first make sure that you haven't lifted any foil paths on the circuit board. To do this work you will have to remove the dmd board. There are tension springs that have to be taken off to be used for screen centering when reinstalling. Use caution when handling dmd. remove sheild and make sure no small copper foils pulled up from the board. Now if the three wires that are used in the 4-pin plug connector are next to each other then you can use the 3-pin plug connector to reinstall them. Just make sure that they connect to the same place as they were removed from. And in the same order. Also, if you look closely you can see how the wires can be removed from one plug connector and installed in the other without cutting anything. Good luck with this, but you can do it if you have patience, Russmann.
May 13, 2009 | Samsung HLN507 50" Rear Projection...
Samsung Dlp- Lamp does not turn on
You most likley have the little copper colored flat ribbon inserted into the plug backwards.Filp it over this should fix your problem.Common mistake.
Jan 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Color wheel/ Samsung
The Color Wheel (part# BP96-00674A) will run you just under $100 from www.samsungparts.com and they offer a variety of shipping methods which will increase your total amount spent. I just received mine today and I ordered it this past Sunday night. My HLR6167W started buzzing and gave me a black and white picture that morning and I was all over the internet investigating the symptom. I elected to go with the color wheel based on what I was seeing and all the different things I read up on. I plan on putting it in tonight and will let you know the difficulty surrounding its installation when I am done.
Jun 24, 2008 | Samsung HL-R6167W 61" HDTV
Samsung DLP HL-P5663W 56" TV Logo
119 people viewed this question
Henry  Thomas
Henry Thomas
