Question about LG VOYAGER VX10000 Cellular Phone
HELP!!!!! i need a replacement lcd screen for my lg voyager
  • 77 Answers
Look on ebay
Posted on May 13, 2009
How can i replace the INSIDE/INTERNAL screen on the LG voyager? i need to either have it replaced or replace it myself ASAP!! please help!!! thanks in advance
The sticky, thick transfer tape and copper ground shield tape on the LCD display to be a real pita. The OE sticky surface pulled off the copper tape and that took some effort to address. If you're determined anyway, try Staples for super thin double-sided transfer tape to repair the copper shield (and thick clear transfer tape for gluing the LCD assy to the inner screen). The thicker adhesive product is similar to adhesive product used to attach automotive exterior trim, except it's made of clear, 100% glue instead of thin sandwiched foam or poly. It measures over 1mm thick and it's used as a sort of spacer. A thinner product will NOT work. A roll of this clear, thick sticky glue product designed for hanging stuff on a house wall costs a whopping $22 at Staples. You may also do it by recycling the old, mangled glue strip, adding time & frustration.
In my opinion, the Voyager repair effort is simply not worth it because you can sell a busted Voyager on fleabay and buy a good used one for about $75 difference. Voyagers eaten by Rotweilers, fallen in the toilet or dropped by motorcycle riders at illegal speed are fetching $75-$90. Folks are getting $125 for clean working black phones with a cracked display and $200 for good one's that need no repair at all. The friggin' screen cost $60 with shipping. So you save about $15. That comes to $3/hour (the job may take 2 to 5 hours to complete) labor for the efforts you took, which is the same wage 1 gets 20 years ago sweeping floors.
If you have any more doubts or need clarifications, please come back to us. Else please accept the solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | LG VOYAGER VX10000 Cellular Phone
My lg voyager has lines comin up from the bottom
if the outside screen is not cracked and its just the internal lcd take it into a Verizon store and they should swap it out under warranty, otherwise if they will not do it send to LG and they will replace. Don't tell them you dropped it at the Verizon store tell them it was in your pocket and something must have pushed against it
Jul 11, 2010 | LG VOYAGER VX10000 Cellular Phone
Lg voyager internal screen doesnt show
if your internal lcd isnt working, it could be part of the flex cable, but unlikly, if it were both screens would be out. it could be a simple pressure crack, its something thats hard to see. if i had some advice it would be to buy a flex or a new lcd...if you need help instaling it, just get back to me and i can walk you through the steps
Mar 11, 2010 | LG VOYAGER VX10000 Cellular Phone
How do i fix my lg voyager if my internal & external screens arent showing up
Your LCD Screen went bad.
Here is a great link to changing out the LCD screen on your Voyager. I just did this with little skill and now it works perfectly. You will need a solder gun though and steady hands......
http://cellphoneforums.net/lg-voyager/t292803-help-voyager-vx10000-lcd-bad-attempting-repair.html
scroll down the screen about half way, look for the posting from YmkerBuilding, he has taken photos as well which is very helpful.
Nov 27, 2009 | LG VOYAGER VX10000 Cellular Phone
I need to find out what to do in order to fix this
People on Ebay will sell you kits with tools and instructions telling you how to replace a cracked LCD screen.. and then once you have the instructions you still have to buy the LCD Screen replacement part. By the time you buy both the instructions and the screen, it will probably be $50.. and it is not easy at all.. I tried it once. And I'm tech support for blackberry folks.. and I'd recommend just selling the phone for parts and getting a replacement.
Oct 26, 2009 | LG VOYAGER VX10000 Cellular Phone
LCD screen broken, have parts, want to know how to change them
THIS is what everybody else leaves out!!! first open ur phone and there are four sticker pads in the corner, use something with a sharp point to remove. Then use a phillips screw driver to remove the screws. the top with now come off, next there is a ribbon cable from the touch screen to the screen itself, On the connector there is a small plastic lever u will need to flip up in order to release the cable. Use a solder iron to remove the wires and it helps to write down on a paper where they go! do NOT LEAVE THE IRON ON THE WIRES TOO LONG!!!!! just enough to melt the solder and remove the wire, same for putting the new ones on! Next carefully remove the screen, it is held in place by sticky tape, be careful not to crack the cover, just be patience and do it slow! and put the new screen in in reverse order!!!! hope this helps!
Tallcool1
May 04, 2009 | LG VOYAGER VX10000 Cellular Phone
My lg voyager got ran over and you can barely see either screen
Assuming everything else still works, you can buy a replacement LCD screen on eBay for around $50 and install it yourself. The LCD screen comes with the front and inside screen.
Mar 31, 2009 | LG VOYAGER VX10000 Cellular Phone
Lg 10000 flickering LCD
It's the LCD screen itself. I recommend that if it is under the manufacture's warranty to get it replaced. I have had to replace so many voyagers for that exact reason.
Sep 23, 2008 | LG Cell Phones
LG Voyager VX10000 Cell phone
I would advise you not to try self repairs if you are not accustom doing that, take the phone to a mobile service center and have the phone fix there.
Aug 21, 2008 | LG VOYAGER VX10000 Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
103 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
