I have and HP Laser Jet 4250N and am having a problem with the envelopes smudging when using tray 1. I have replaced the fuser and have tried different envelopes, but still have the same problem, have also adjusted media type to envelopes to increase heat from fuser unit
SOURCE: PIXMA 830 Smudges when printing envelopes
I can't find an "envelope" option on the printer. All I see are "plain paper" and then photo type paper settings.
SOURCE: envelopes smudge
I have been informed that these fusers have a seperate heating element in the middle of the heat roller for envelopes to save energy and it's temperature is not sensed by the thermistor.If I trick the printer (with paper path tests) into printing envvelopes while thinking that it is letter the fusing is ok.
SOURCE: Poor quality smudge and ink blotting marks in the centre of any printed document
Try performing a test by printing a test page from Tray 1 and open the top cover as soon as the paper is 60% inside. The paper would jam below the toner cartridge before it reaches the fuser. Remove the toner cartridge carefully and verify if the smudges occur. This would eliminate the fuser. If the print quality is fine, then you need to swap the fuser.
SOURCE: ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
