Question about Dell Dimension 3100 PC Desktop
Monitor keep going into "sleep" mode
My LCD Monitor (Dell) keep going into "Safe" mode 1 few second after the computer boot up. In this mode, the monitor go blank to save energy. It is like the computer has been idle for a long time. If I turn off and on the monitor, the screen display for a couple second and then go into "safe" or "sleep" mode again. thanks
  • 2 more comments
  • Anonymous May 12, 2009
    yes. the monitor is hooked up to the computer.
  • vktse May 12, 2009
    yes. the monitor is hooked up to the computer. when it is disconnect from the computer, it won't even show anything since there is no signal coming in.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    See if you can try to reset the defaults on the monitor.
  • Ben Wabnick
    Does it do this when the monitor is hooked up to the computer and when its disconnected from the computer?
    Problem Solver:
  • 9 Answers
Try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
Posted on May 14, 2009
    Problem Solver:
  • 5 Answers
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
Posted on May 13, 2009
Monitor goes black seconds after showing desktop
Does your monitor go black because it went to sleep, does it turn off? Do you have any lights on the monitor to indicate what it is doing?
Also I would boot into safe made by rebooting the computer & tapping F8 when the bios appears. You should be prompted with several options, one of which is "Safe Mode". Choose this & report how the monitor behaves.
Jul 24, 2012 | Acer X193W LCD Monitor
My Dell Monitor keeps going into sleep mode immediately after booting up.
Make sure your computer's screen resolution is fine for that when you power up the computer press F8 key 5 to 6 time untill you can see safe mode and other menu if you are able to see safe mode then enter in enable vga mode then enter as admnistrator go to control panel->display property ->settings change screen resolution to 1024*768 then apply and restart it.Let me know if you need further assistance.Thanks for using FixYa.
Aug 03, 2011 | Dell Dimension 4600 PC Desktop
I have the same problem as this one does. my monitor goes black when windows boots. I can see the computer load at fist, then when the window icon shows. the screen goes black. WHY ?? im thinking there is...
you can try Fn + F8 and see if the display was toggled for external (Wait about 15 seconds before pressing a 2nd time) that is the keystroke from (LCD, External, LCD and External)
If no go, see if your system keeps video displayed in the safe mode (F8 at boot, select Safe mode from the boot menu)
you can also run diags on the LCD (Power button + D) or PSA diagnostics and see if the video stays on out of the operating system (Power +Fn)
Jul 21, 2011 | Dell Latitude D520 Notebook
Have a westinghouse lcd monitor, 1080p that will not work with my older computer running windows 2000. have changed the resolution and HZ to specs. It will come up at computer boot, show the windows...
This is a windows issue which will not support display boot in safe mode by hitting f8 key after post after your in in safe mode change settings in control panel till it works,if it doesn't work windows does not like your monitor.
Jan 07, 2011 | Computers & Internet
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
Are screen savers good for TFT monitors
unless the monitors are being turned on and off frequently the sleep mode idea is alot more efficient
Mar 30, 2010 | Dell E197FP LCD Monitor
Computer in safe mode and monitor will go to sleep mode....help what can I do...my husband tried everything....
First, Shotdown your computer from start ,
then remove your computer power, remove VGA cable, remove VGA power cable. then
1- connect vga cable to computer.
2- connect VGA power but do not power on.
3- connect computer power on but do not turn on
4- turn on computer first and 3 second turn on your lcd.
if NOT try powering on computer then Monitor then power the computer then monitor.
IF NONE worked, YOU may have LCD that need drivers from manufacturing, some newer models required that, Specially for vista.You may use older Monitor to get drivers to computer and extracted, then you may connected, you will have solved the problem.
Goodluck
JMC
Aug 12, 2009 | Dell Dimension 4600 PC Desktop
5 sec after starting windows the monitor goes to sleep itself.
go to safe mode.. change the power settings for windows...
to go to safemode.. simply restart your computer.. then press f8 several times til you see the boot menu.,.. select safe mode.. from there.. you should be able to boot windows.. change the power settings in control panel
Jul 09, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Fuzzy display on LCD and External Monitor
it sounds like you may have an updated driver that doesn't work with your machine. boot into SAFE mode. on a dell it is hitting the Del button for most of them as it is booting up. then choose safe mode. For other dells it is F1 or F2 you just keep hitting the button while its booting up until you hear it start to beep at you. then look for safe mode. while in safe mode you can then change the driver, but for those specifics you have to go to dells web site. http://www.dell.com/support/home/us/en/19/quicktest?c=us&l=en&~ck=mn
Dec 03, 2017 | Dell Inspiron 1200 14.1 XGA LCD...
Dell Dimension 3100 PC Desktop Logo
1,078 people viewed this question
Alun Cox
