Question about Kenmore 16.7 cu. ft. Freezerless Refrigerator
The frreezer is too cold, the refrigerator is not cold at all.
My ffrostless freezer is too cold. Ice crystals are forming on the food.
The rerrigerator is warm.
Could the water line be clogged?
  • 159 Answers
Most casses the gas level getting too low so the fridge gets warm and the compressor never puts off
Posted on May 16, 2009
Icy crystals forming on food in freezer
Ice crystals forming on Frozen items in the freezer is an indication of an air leak caused by either a bad seal leaking seal or an open door to the ice maker Ice chute door
Appliance 911 Sea Breeze
May 17, 2016 | Frigidaire Refrigerators
Freezer is running constantly. ice crystals formed on outside of packaged foods. food is still frozen.
the door was left open,if you find frozen water droplets on the food packages or ice crystals it forms from the warm air coming in,make sure all the packages are pushed in and not hitting the door and you can tilt the fridge back a little so the door will close with a slight push.also check the ice shout door and make sure no air is leaking through it,you'll know you'll see all ice around it.you can check the condenser coil and condenser fan to see if it needs to be vacuumed,the machine will run longer if the coil is clogged with dust or if the fan isn't blowing,the coil should be cleaned every 6 to 12 months.hope this helps but it sounds like the freezer door was left open.
Sep 06, 2011 | Frigidaire FRS23KF7AB Side by Side...
Freezer not cold enough to freeze food and ice maker not making ice
Hi first thing you want to check is if the freezer is frosted up in the back, also the center mullion/separator between the refrigerator and the freezer and see if it is warm to the touch. If it has frost you are looking at a defrost problem, if its warm in the middle your looking at dirty condenser or bad condenser fan motor. If neither of these are present check to see if fan is running in the frreezer, and if its and none of these other symptoms are presenst you could have a freon leak or sealed system issue.
Sean
Mar 26, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice crystals are forming throughout my bottom freezer
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 15, 2011 | Amana ABB1927DE Bottom Freezer...
Refrigerator not cold freezer working properly turned food section to max, cleaned coils
loook for ice build up in back of freezer . and if found you have a failed defrost system .. the coil is blocked with ice and this prevents the cold air form getting to the fresh food side . look at the heater in the back of freezer ... mm . if heater is ok then replace the adative defrost control . / a very common part failure .. mm
Sep 30, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Jul 10, 2009 | Kenmore Refrigerators
Freezer-Ice forms on food in the freezer and ice crystals form under the ice maker, ice cream products get soft
check the door gasket to see if theres any tears or if its dirty, also check the coil on the back to see if theres any dirt on it if so it needs to be cleaned.
Jul 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Refrigerators Logo
189 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
