Question about Frigidaire ATF6000ES Front Load Washer
Cannot figure out how to put filter (plastic) back in the pump, hose unit...where does it go?
On the frigidaire front loader took all hoses and pump off the clean out all the stuff, but now i cannot get the plastic filter thing back in and not sure where it goes
  • 5,911 Answers
If your model number is correct, Appliancepartspros.com has an excellent exploded view diagram of your washer that you can use as a reference to help with reassembly. Just type in your model number and reference Section 4 (Motor/Tub). If you have questions, please let me know. I hope this is helpful to you.
Posted on May 12, 2009
Frigidaire front load washer GLTF2940FS barely drains at all. Hose is clear of debris and properly positioned in house drain (6 to 8 inches). Is there a drain pump filter that is accessible from the back?...
Yes, there is a filter on your machine. If you look in from the back, on the bottom of the tub is a hose coming off. Remove the hose from the tub section and inside of it you will find the filter.
Have a great New Year!
Jan 03, 2011 | Frigidaire GLTF2940F Front Load Washer
My frigidaire front laod washer has an E20 error message.
E20 error is known for pump out issue.The first thing I recommend is to take off the front bottom cover(below the door) tilt the washer back some,remove the clamps and hoses from the drain pump.It should be on your right hand side.Check the pump and hose to remove the clogging.This tends to be a common problem with Frigidaire front loaders.Now when you all done with that put it back together and do a test run.
Apr 11, 2010 | Frigidaire ATF6000ES Front Load Washer
How to unclog drain hose/pump? my front loader
First of start by checking the rubber gasket seals around the door and making sure those are good and clean and dry. Then inspect the barrel itself. My daughter loves to leave scraps of paper in her pockets that then get stuck in my front loader. Clear any debris from the barrel. Does your machine have a small front access panel or back access to get to the filter? Most front loaders have some sort of filter on them apart from the barrel. If you can find this part, it is a common culprit. Mine is a tube shaped basket with a front access panel on this one. On the front loader before this one is was back panel accessable under the drum. when you check these have a bucket and some thing mop up with handy, towels, mop, etc. One other thing to consider is the drain hose from the machine. I have flushed mine using a garden hose in the yard and used a little bleach.
May 12, 2017 | Frigidaire ATF6000ES Front Load Washer
E20 Error - how do I access the inside to check for blocks?
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. (You may find the drain hose here, on left) The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Mar 21, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a 2 year old frigidaire front load washer.  The spin cycle starts, but only runs really slow.
all washers must drain before will go into high spin.is your's draining?the front loader type's of washers are good for getting the pumps blocked up with stuff that was in our pockets etc....too get to the pump remove the bottom front panel.the pump is the white or tan unit with two hoses to it and two wires on the right side of the washer..there are some bolts retaining the pump to the washer floor.remove and remove hose and drain into a bucket.then clean out pump.if you turn off water at house fill hose's you could put in spin at that point to test.then put all back together.if you need more advise you can email th-u fixya. God bless ,tom
Jan 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigdaire washer
ok no probelm..you have a front loader ,,first un plug unit,,now at your feet theres a toe panel,,3 screws remove them and the panel will slide down..now off to the cener left the thing with the little fan on front and the 2 black hose coming out,,1 hose lead out the unit to your drain and the other hose comes down from your tub...take that 1 of from your tub to pump but take it of from the pump ,,if its water in the unit ,,dip much as you can out and then put towel on the floor..now see whats jamming pump..im here for any questions,,,reverse to put together..onthejob
Jan 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore front loader washer
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Jan 25, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
126 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
