Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Can't delete pin number from 377LM wireless keypad
Tryed to use instructions - did exactly step by step did'nt work. now I have 2 pin numbers programed that work, but I need to get rid of the first one, How?
    President:
  • 3,197 Answers
The way to do this is to hold the smart/learn button in for 6 seconds. This will erase the memory and none of your remotes or keypad will work. You will have to program them all but your extra PIN will be gone.
Posted on May 13, 2009
I need a remote keypad for 41a5021-1e lift master. What model will work for this unit
check the liftmaster web-site. also any garage door sites may have parts offerings. google the part number as well.
Nov 05, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
976lm reset
Follow these instructions to change the PIN. It will delete the existing one.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jan 20, 2012 | Sears Craftsman LiftMaster Chamberlain...
Keyless garage entry pad 53754 (315mHz) need to program a temparay passcode, how do I do this? thank you
1. Press the four buttons for your personal entry PIN, then press and hold the * button. The opener light will blink three times. Release the button.
2. Press the temporary 4 digit PIN you have chosen, then press ENTER. The opener will blink four times.
3. To set the number of hours this temporary PIN will work, press the number of hours (up to 255), then press *.
OR
3. To set the number of times this temporary PIN will work, press the number of time (up to 255), then press #. The opener light will blink once when the temporary PIN has been learned.
Test by pressing the four buttons for the temporary PIN, then press Enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Keypad does not operate door
You can try programming the keypad but I have a feeling it has just quit working. To program it: locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your PIN and press enter.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Temporary passcode
Press the temporary 4-digit PIN you have chosen, then press Enter.
The opener light will blink four times.
To set the number of times this temporary PIN will work, press the number of times (up to 255), then press #.
Test by pressing the four buttons for the temporary PIN, then press enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
My keypad does not have a enter button and im trying 2 reset the password....what do i do??
You must have a wired keypad. To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Jun 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Changing PIN on Key Pad
can you please provide the exact model number of your Security device...
Thanks
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Reprogram garage door keypad?
I have a Liftmaster 377LM wireless Keypad no maual
How do I reset it?
Jul 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
May 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
300 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
