Question about Inverter AIMS Power 5000 / 10000W
AIms 5000 W inverter worked fine on Friday, turned it on monday, bars light but no power coming out.. Any clue?
  • 74 Answers
It could have an internal fuse or two
Posted on May 12, 2009
My 3000 watt aims inverter/30amp charger seems to work but the charger will not charge/transfer when I turn on the generator. Charging indicator will not come on. It does transfer the generator power
dear see that :
1- the range of voltage which inverter work between it for example 180-260 v
2- most small generator voltage reach more than 260V so the inveter not work
3-check the frequency of genaratoer if it not fix the inverter will mot work
Oct 12, 2014 | Aims Power AIMS PWRIC300012W 3000 Watt |...
How fix a inverter
Too vague, but look for bulging capacitors and replace them as needed.
JOAT
May 09, 2014 | AIMS 5000 Watt 12 Volt DC Power Inverter...
I have a problem with my inverter in that when i load,it cutts off, and at that moment it is only one lighting point that is on,it tells me that their overload and fuse blown,what do i do?
I have an Aims 2500 W inverter that was damaged from an accidental connection of voltage from the grid. i replace all of the IRF260n FET transistors but it is still shutting down as soon as it is turned on.Can some one tell me if those FET must have a drive at the gate. Before it will work
Feb 17, 2011 | Inverter Aims Pure Sine Wave Power...
I have a Aims Inverter PWRINV5000W with all the lights on but no output at plugs.
Hi!!
There is a fuse or thermal device for the AC outlet(s) protection, is either next to the outlet or same place but inside the unit. The cover need to be removed to change/reset it.
Let me know if you found it. Good Luck!!
Dec 08, 2010 | Inverter Aims Pure Sine Wave Power...
Red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
Overload light on Aims 5000w inverter
try to disconnect all cables from front and back, then turn the unit on and let all the stored charge drain and reconnect and test...make sure the unit grounded
Sep 06, 2009 | Inverter AIMS Power 5000 / 10000W
Aims 5000w inverter
Try shutting down the load completely, then power up the inverter with no connected load. Then bring a little on at a time and see what happens.
May 21, 2009 | Inverter AIMS Power 2500 / 5000W
Aims Inverter PWRINV5000W Installation Manual I just went to install it and no manual in the box
Here you go- contact info for Aims. They can provide you with a manual. Good luck....gary
AIMS Power Contact Information:
9736 S. Virginia St. STE A
Reno, NV 89521
Tel: (775) 359-6703
Fax: (775) 359-6753
e-mail:
sales@aimscorp.net
techsupport@aimscorp.net
customerservice@aimscorp.net
Jan 10, 2009 | Inverter Aims Pure Sine Wave Power...
Aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
Inverter AIMS Power 5000 / 10000W Logo
412 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
