Question about Karcher 2500 PSI Pressure Washer
No pressure from pressure washer
It starts squirts water without pressure
  • Anonymous May 13, 2009
    I have the same problem. When I pull the trigger there is no pressure other then a stream for a few minutes, then it will work. Then when I let go of the trigger it will take a few minutes agin to start. Please help. How do I fix this problem?
    President:
  • 957 Answers
Do you plan on doing the repair yourself. I need more info, when you supply water to the pressure washer, pull the trigger to purge air from pump, and start the machine. Do you see water coming out from the bottom of the pump? Do you hear the pump working or is it quiet. If you hear a cycling pattern or hear the pump trying to push the water out but it isn't, then you may have a blockage inside the trigger or the spray tip. If the pump isnt building pressure then you may have a pump problem. A stuck check valve, cracked plunger, bad seal, or could be air bound.
Posted on May 12, 2009
Hy does water squirt out around the nozzel
Inside the nozzel, where the tip locks in, there is a groove for an o-ring. If that o-ring is missing, water will leak around the tip as you describe. Sometimes when the tip isn't fully seated in the nozzel and you pull the trigger, the tip goes flying out. The o-ring will fly out also. Most people find the tip but never see the o-ring. The o-ring is usually carried by any company or store that carries pressure washers.
Jan 20, 2013 | Garden
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
AT FIRST WITH JUST THE WATER ON (PUMP OFF) I SQUEEZE THE WAND AND WATER COMES OUT ABOUT 3 FT. THEN WHEN I START THE PUMP AND SQUEZE THE WAND ONE STRONG SQUIRT COMES OUT THEN GOES BACK TO ABOUT 4 FT. NOT...
Hi, W/D here.
Leave the water on, and hold the trigger down for about 5 minutes to get all of the air out of the system. Letting off of the trigger occasionally and then opening it up will help displace any air in the chambers. While still holding the trigger down, start the washer. Should put up your desired pressure.
Best regards, --W/D--
Feb 14, 2011 | Comet Axd3020g Pressure Washer Pump 27 Gpm...
The machine leak water from inside, and it does not have pressure.
hi,
make sure everything is clean;the inlet screen etc. Take a flashlight and look inside were the hose connects and make sure nothing is inside.To do a simple test;connect the hose,turn on the water,and WITHOUT starting the pressure washer,squeeze the trigger on the gun;you should have a steady stream of water coming out,about the same as a kids water gun;like a super soaker;If not,then your problem is something is restricting the water inlet,or if the washer is old,mineral deposits inside a passage.If it does squirt out pretty good,then your washer is tired,or you used a cleaner that's NOT compatible with pressure washer seals,or maybe the unloader is stuck,and won't allow the washer to build pressure...........If it's getting a good supply of water,the only thing that builds pressure is the seals,and the unloader.Other than that,there is a small passage were the outlet is,and that could be restricted with mineral deposits,but I would take apart the hose and check for debris in the line,to be sure Hope this helps!!
http://www.pressureparts.com/OwnersManualsK1.aspx
Jan 31, 2011 | Karcher PSI Electric Pressure Washer
When hooked up, (electric+water) unit will not activate. Power wanr is squirting water but motor is not on.
Dear Sir,
This is a problem like the ones I explained. I will write again the explanation.
Dear Sir, What happened is that you have a control valve (Spill Valve)..that when pressure is created it will closes down and puts off electricity by hitting a micro switch. This happens if one leaves a lot of soap in the system or more often the machine is stored under pressure. Never store a power washer under pressure!! Now all one has to do is locate the spill valve ...lubricate or change with a new one. Always lubricate with silicon grease. Also never put on a power washer on without water being fed.
The spill valve is usually located where you see 2 wires coming out on the machine inside.
Well just a small reminder.....if you left the machine stored with pressure...most probably you have the spill valve jamed in the closed position, thus cutting electricity off.
Regards, Fulltech
Oct 03, 2010 | Campbell Hausfeld 1800 PSI Electric...
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
No high preasure at nozzle
Try starting the washer up without a nozzle clicked in and purging water through the pump, shut it down and install the nozzle and restart, if the motor lugs then it is making pressure, if the pump squirts water out of the by-pass immediately and or constantly it may be a stuck bypass and not a bad pump.
May 26, 2009 | Psi 2500 Mobile Pressure Washer 5hp Honda...
No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Oct 28, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
651 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
