Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Power surge and breaker went off, turned it back on and washer comes on but not the dryer, is there a reset button
Power was off and now back on , the washer comes right on but the dryer does not . is there a reset button, or something else
  • 323 Answers
The dryer is on a different circuit as it is 240 volts. Look in your breaker box and find the breaker for it (it should be tripped half way). Turn it completely off and then back on. There is no reset button for it. Make sure the plug is securely pushed all the way into the outlet.
Posted on May 13, 2009
  • Dan Todd May 13, 2009
Is there a reset button for Frigidaire AEQ7000EGO? Had a power surge/outage and now dryer has no power, although plugged into electrical outlet.
Good Morning Friend,
I understand you had a power surge at your home, and now your Frigidaire Affinity dryer, model#, AEQ7000EGO, has no power. I do see that you have checked to make sure that it is plugged in. I suggest checking the circuit breaker or fuse that the dryer is on. Make sure that the fuse is not blown or the breaker tripped. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
First, plug a fan or hair dryer into the plug to make sure it has power, if not, check to see if the GFI plug hasn tripped. All electrical plugs that are near water have to be on a dedicated electrical line that has a trip-breaker (GFI) built into the plug. Try unplugging the washer for several minutes to reset the electronics. Those are the only two quick fixes I can think of. If you have an electric dryer, it will have its own 220v plug and won't be affected like the washer. If the dryer is gas and is plugged into the same outlet, try unplugging the washer to reset first before you call a repairman for the washer. If you have homeowners insurance, they may cover the damage.
Jun 21, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
After power outage dryer will not come on model # 96573220
Hello Edward, Is it possible that the electrical circuit breaker is tripped in your breaker box? Try shutting the breaker off and turn it back on.
Feb 23, 2014 | Kenmore 60172 Electric Commercial Dryer
Could this be a power surge?
More likely power went off line and when came back tripped the breaker......
Apr 18, 2012 | Televison & Video
The dryer was working and the electricity went off and came back on while I was outside. I thought it was done, took out the lothes and put in new wet clothes, turned the timer knob and hit the button. It...
Try resetting the dual breakers for the dryer in the house electrical panel--push off, then on. Power surges from the utility can cause the breakers to trip. If this doesn't help, then you probably have a problem within the dryer. Good luck!
Feb 06, 2010 | Dryers
I have an electric dryer. The breaker went off and when reset the dryer would not come back on. I am not sure if the push button on/off switch is now working or if there is a reset on the dryer
I have a Kenmore 80 series electric dryer. The light comes on when the door is open so I know it is getting power but dryer will not turn on. Is the push button not working or can I reset the dyer?
Dec 06, 2009 | Roper REX4634KQ Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Had power outage and now the Neptune Washer won't even light up. Washer was not in use at the time. Checked the breaker and outlet and all live and functioning. Is there a reset button that will reset the...
no! did the porew surge when it came back on,like the lites in the house went briter than normal/may have damaged main control board in top console.you will also fine a tech sheet up there.see if you can get some glues their.God bless.tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer WM-2277HW and Dryer wont turn on after power outage.
there is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Oct 19, 2007 | LG WM-2277HW Front Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
277 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
