Palm Treo 500 Centro Logo
Posted on May 12, 2009
My phone is locked in hot sync mode
My cell went into a hotsync mode and i havent been able to get it out it has been like that all day and ive tried everything t fix it i even took the battery out for awhile and it did not work.,
Anonymous
Level 1:
  • Contributor 40 Answers
  • Posted on May 12, 2009
Anonymous
Contributor
Level 1:
Answers
40
Questions
0
Helped
18080
Points
94
Hi, you will have to do a System Reset. Take off the back battery door cover, Find the Reset Button(Black) Press the RESET button gently 1 time. This will restart the Phone. This should correct the problem. If this does not fix it please contact me for step 2.
My cingular palm centro wont stop hot sync
I had the same problem with my phone a few months back. I took the battery and sim card out of my phone for a few days and then put them back in and it worked. I still have problems with my phone but not with the hotsync feature.
1helpful
2answers
Palm centro goes into hot sync mode
IN PREFERENCES GO TO PERSONAL/BUTTONS THEN AT THE BUTTON LOOK FOR HOTSYNC PRESS IT THEN ON CABLE CHANGE IT TO PHONE; IT MIGHT BE THE PHONE HAS A PROBLEM WITH THE HOTSYNC CABLE CONNECTION. NOW IT DOES GO TO HOT SYNC INSTEAD IT GOES TO PHONE. NOW I'M TRYING TO FIX THE PROBLEM BUT MY PHONE STILL USEFUL.
SORRY ABOUT MY ENGLISH
2answers
How do i transfer my pictures from my palm centro to my computer?
use the palm quick install and browse through picture files and add them. You will need to first of all put the hot sync cable on your phone then hit the button on the cable connector, give it some time, if you still cant do it, read below
if it says it cant connect, go to hot sync on the home and then below the hot sync button ON THE SCREEN, Where you see switch the IR to a PC/handheld click it and go to the second option. If that still doesent work, on your PC go to all programs then look for palm, go to that file and click hot sync now the hotsync is turned on the computer then after that do all the steps in the first paragraph.
thank you
Hot sync doubles appointments
I went into the HotSync Manager and changed the settings to Desktop overwrites handheld. That did the trick!
5answers
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Hot Sync
Yes. Look through all of your apps for "Hotsync" when you open this, you will see the normal screen that comes on when you push the hotsync button. touch the hotsync logo button on the screen and it should work. Hope this helps.
Manual Hot Sync
If u need to make connectivity between computer and Palm mobie then u need to install hot sync software on ur Pc and activate hotsync option from ur mobile then with cable u can transfer the data . if u  not have proper software of hotsync then download it from palm Site.
Gizmo1
2answers
When I hot Sync my Treo 650, my tasks hot sync fails
I changed so that the desktop over-rides the handheld and the hot sync went through. This is not the way I perfer this, but it worked. I have not switched it back to sync the files yet to see what would happen.
1helpful
2answers
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
3answers
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
