Question about Linksys SR2016 16x1000 Mbps Networking Switch
Want to have wireless with my Limksys Sr2016 switch
According to Comcast, my wireless router (linksys WRT300JN) is slowing down my connectivity. I'm currently using this confirguration.
Cable modem to the WRT300-N, from there port 1 to a 16-port gigabyte switch (Linksys SR2016). This is for a small home office (5 computers), with a Xbox and Directv-on demand.
Would like to have wireless option of laptops, etc. Do I need to get a Access Point and can I run that off one of the ports on the switch?
Thanks for you help
  • sean898 May 13, 2009
    Thank you, will try that!
Go to: www.speedtest.net with a laptop on your network.
Find your speed. now repeat on same laptop plugged directly into the cable madem.
Do the settingsa change much?
If so, your network is at fault. If not, Comcast is lying to you.
Posted on May 13, 2009
How to reset linksys SR2016 router to factory
  1. Hold the reset button on the back panel of the Linksys router for 30 seconds. ...
  2. When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Jul 07, 2016 | Linksys SR Computers & Internet
Forget my password
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 18, 2011 | Linksys Wireless-G WRT54G Router
Router pasword
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Dec 07, 2010 | Linksys Wireless-G WRT54G Router
I HAVE A NEW HP DESKTOP AND AN OLD LINKSSY WIRELESS G
Hi Vivian,
Chweck you cables and where they are conencted.
You will need to make sure that the Comcast modem is providing internet, you can do this by connecting your laptop to it using ethernet directly if it connects to the internet, that will be a good thing.
From your comcast Modem, the ethernet Cable should go to the linksys where it says "WAN". this should give you an internet connection and make your comcast modem communicate with your linksys Router.
Jul 22, 2010 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
No website through a limksys router
Are you trying to connect via wireless or wired?
Could be an IP conflict between your modem and router. Although rare, it does happen. Change the
setting in the router to something different. Default address for Linksys is192.168.1.1 - try changing it
to 192.168.0.1 or 192.168.1.2
Jul 09, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
I cannot connect with linksys wireless router
From your description, you appear to be connected to the router fine.
Try powering down the modem from Comcast for about 2 minutes then power it back up. If it doesn't come back, call Comcast service as it is likely on their end.
Hope this helps.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Linksys to homeportal
In order for you to make the linksys wireless router and the homeportal 1100 to work together they should be connected via CAT5/ethernet cable, you cannot connect them wirelessly...
Oct 26, 2008 | 2wire HomePortal 1100 Router...
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Linksys SR2016 16x1000 Mbps Networking Switch Logo
212 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
