Question about Proform XP 542S TREADMILL Drive Motor
Incline on treadmill is acting strange
Proform xp542e incline doen't go all the way up or down it goes all over the place tried to reset the incline but it didn't work when the up and down arrows are pushed the read out skips numbers and it gets mixed up on it's readings it will go from 5.5 to 8 and then to 10 and it also goes to 10 in the middle of going up or down
Open the motor cover. There should be a service sheet in there.
Read Option 2 & try it.
Posted on Feb 12, 2011
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
My Proform 380 treadmill will not run the incline goes up and down but the motor/ belt does not move
ADJUST 1) Reed swithc and optic disk.11_15_2011_9_21_16_am.gifIf after you did these adjustments Not work, replace the sensors.11_15_2011_9_21_36_am.gif
May 31, 2011 | Proform Crosswalk 500 Treadmill
The proform 980 turns on but just goes to incline
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
Apr 30, 2010 | Proform 980 CS Treadmill
Incline does not work
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 19, 2010 | Proform CrossTrainer Treadmill
Proform 740CS runs okay but the incline does not
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
My ProForm 530 is stuck in the incline position. Once the key is inserted, the treadmill is steady trying to incline past 12 and does not respond to me pressing the ''incline down'' button. It continues to...
plug her back in, insert key, let her do her thing while u just sit back- I believe shes trying to Calibrate. If so, she will go up all the way,then back down on her own. after she's in down posistion, console will beep/beep and she has reset herself.. let me know what goes on after u do this. David
Jan 05, 2010 | Exercise & Fitness
Incline goes up and down constantly. Console doesn't work
It sounds like it's in calibration mode and you need to let it go all the way up and then down and set itself. If you have done that and it keeps going into that mode then you probably pulled or moved some wiring while moving it.
Sep 15, 2017 | Proform iLog 750 Treadmill
Proform XP 542S TREADMILL Drive Motor Logo
460 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
