Question about Acer Computers & Internet
My daughter took the keys off and in trying to put them back on some of the under brackets broke. I am trying to find where I can purchase these (otherwise I have to take it in for service which is g
I have an Acer eMachine Model No 620-5133. My daughter took all the keys off. While trying to put them back on some of the brackets (under the keys broke). I am trying to find somewhere to purchase these brackets. Otherwise I have to take in for service (and pay more to get it fixed then it cost in the first place). Can you help find where I can purchase the brackets?
  • Acer Master
  • 32,281 Answers
It is unlikely brackets can be purchased. I found brackets vary between keyboards even on the same model laptop.
Your best bet would be purchase a replacement keyboard.
Check on the Internet for replacement keyboards.
I purchased keyboards from Yall Store for approx. $60
Use this link
www.yallstore.com
Posted on May 12, 2009
Sounds like the flex plate is broke..only when put pressure on it.could it be CONVERTER
it could be, since you have the tranny out, still I hope, replace the torque converter, your key phrase, when putting under pressure, but this may also refer to the PUMP ! but the noise points more towards the converter !!! if pump went, you would\'nt have any drive at all ! GO FOR IT, replace converter .
Mar 14, 2013 | 1995 GMC Sierra
I broke screw that holds the brace for handlebars. i took off the handle bars but cant take off the bracket. 2002 honda shadow motorcycle.
Go to any hardware store and purchase an ez out. You drill into the screw and remove it with the easyout
Mar 14, 2013 | 2002 Honda VT 600 CD Shadow
I had to change my alternator on my 1995 f150 with a straight 6 4.9l. when i took the old one off i turned one bolt a centimeter and it broke i couldnt get the ac compressor off cuz its bolted to the...
Use 6-point wrenches or sockets to eliminate slip. From your post:
"i went to go drill the bolt out i got it drilled out but i was putting a new bolt in the alternator bracket cracked so i need to know how i can get the ac compressor off..."
I cannot tell whether the bolt cracked or the bracket cracked from your post above.
Do you have any kind of small cut off wheel?
Apr 26, 2017 | Cars & Trucks
Broke my shifter on the collum can i change it
YES COMPLICATED BUT YES ; PULL THE STERING WELL;REPLACE THE BRACKET THAT YOU BROKE IN THE STERING COLUMN PUT IT BACK AS YOU TOOK IT A PART YOU WILL HAVE TO HAVE A REAL GOOD PULLY PULLER I HAVE DONE IT; THE MORE YOU DO THE EASER IT IS !?
Aug 30, 2011 | 1998 Toyota Sienna
Driver side window fell into door, took apart and the plastic brackets broke off window. What do we need to buy to fix this? Do we have to buy the whole motor assembly or can we just buy the plastic...
It is nearly 10 years old. While it is apart get a new regulator from a parts store or ebay so you are not taking it back apart next year. Those connectors can be had at stores which sell paint and body supplies for cars, and at auto glass shops. I would pay the glass shop to remove and replace the regulator and put the door back together.
Dec 12, 2010 | 2002 Pontiac Grand Am
I have a 1985 Camaro Berlinetta with a unknown 305 in it. The noise on the starter broke in half I took it out it's for a 1980 Impala. I tried a 1985 Camaro starter no luck. I put a new 1980 impala starter...
If I remember correctly, there were two noses for those starters, either should work as the difference was that on one both bolts were long, the other used a long and short one.
The one thing that may be missing there is that both starters used a front support bracket that either fastened to the case or to one long bolt that holds the starter together that had a short threaded extension on it. the other end of the bracket attaches to the engine block. Under load, that bracket keeps the starter from trying to tilt up and break.
Another thing that can break the nose is an ignition cross-fire. that can shock the housing and also give you that problem. Make sure the ignition wires are good as well as the cap and rotor.
Nov 07, 2010 | 1985 Chevrolet Camaro
I purchased a 1997 Honda accord Se for my 16 year old daughter but the radio/cassette doesn't work. I want to put in a cd player without paying a fortune, what is my best option?
i would recommend purchase an aftermarket cd player. you can also purchase a cd player is dash kit. that will come with the wire harness connector and the brackets to hold it in place.
Dec 10, 2009 | 1997 Honda Accord
My daughter is in Sechelt , BC and is driving a 94 Explorer. The tensioner pulley broke off from the bracket and was lying on the engine. As I can't physically look at it (she sent me pictures), it ha
honestly just replace the tensioner. its a complete unit. Unless you have the bolt and washer for the bearings are not bad then, just bolt it back and make sure it spins freely
Apr 12, 2009 | 1994 Ford Explorer Limited
Need picture of alternator assembly with brackets 99 Malibu
go to any auto parts store and buy a haynes manual for your car. they are based on a complete teardown of vehicle. this book should show you. only about 20 to 25 bucks, good- luck!
Mar 22, 2009 | 1999 Chevrolet Malibu
2008 Chevrolet Cobalt steering wheel locked
If it is an automatic, the transmission shifter is failing,should be covered under powertrain warranty.
Dec 28, 2008 | 2006 Chevrolet Cobalt
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
