Question about Cub Cadet Street Sign- tractor lawn riding mower parts
New parts may not put wires back on wright
''cub cadet 2166 16hp wiring for ignition module to digital speed advance module''
  • 246 Answers
Hello clmcpeak:
>>You can View a Breakdown/IPL of this Unit at this Site Addy; http://www.jacobisalespartslookup.com/home.asp and Select the Cub Cadet Logo. Now Select Shop Online Parts Look Up. Now Select the OEM ( Cub Cadet) and Select the Model Tab. Then Enter the Model Numbers and Click Search. Then Double Click on your Model in the Results Area. Then Select Sectional View. Then Select the Section of the Unit you Wish to View. Select the Electrical File.
>>Most of these Breakdowns have a Schematic of the Electrical Systems of the Mower and Engine. If No Schematic of the Engine, then
Send me the Make, Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
Im looking for a wiring diagram for cub cadet lt1040 riding mower
https://www.partstree.com/parts/cub-cadet/mowers-lawn-garden-tractor/104-cub-cadet-garden-tractor/wire-diagram/
wiring diagram for cub cadet lt1040 Google Search
May 22, 2016 | Cub Cadet Garden
Not getting spark on my cub cadet HDS 2155 lawn tractor
check all the safety switches and if it isn't one of those then disconnect the kill wire from the ignition module and try it. if it still doesn't fire then it is the module, if it does then it is in the kill wire
Sep 22, 2013 | Garden
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
Adjust idle speed
on the top of the carburator there should be an adjustment to set the idle speed
Apr 25, 2013 | Cub Cadet Garden
Cub Cadet 2150 ignition problems. Need a wiring diagram to source problem.
don't have a diagram but i would check the safety switches jump them while looking for the bad one with a paper clip
Apr 11, 2012 | Cub Cadet Garden
Cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Jul 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My 2166 Cub Cadet pops and backfires at high rpm.
try replacing the air filter first or check it with the filter off, you may only need a new filter. if not get a mower or bike shop to test the coil they will let you which one to buy
Jul 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
338 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
