Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic projection TV front LED blinks 5 times
My panasonic RP TV developed a problem where it was powering on but just had a small rainbow of colors in the middle of the screen and rest of the screen was dark. I replaced the vertical IC (IC451) and also the two convergence ICs. The convergence resistors are also fine. Now when I turn on my TV, it produces a ticking sound and then whines as if the HV is trying to come up. But then it cuts off, the front LED starts blinking 5 times and repeatedly indicating faulty IC4511. I have also replaced the flyback and the HOT but the symptoms remain the same. I also do not see any apparent problem with the caps etc on D-board. What could be wrong with the set? Can anybody help? The chassis is AP-825. Thanks
  • Safk May 14, 2009
    IC-4511 is the main processor located on DG board which is mounted on the A board. It is not user replaceable because of very fine machine soldering. The number on DG board is A13315. I did not replace it as yet because I think there may be some other problem that is coming up as a main processor fault. Anyways, the DG board also costs more than the TV is worth. Any other hints?
Geodesic
  • 5 Answers
SOURCE: Big mistake
what was the origonal symptom before replacing the flyback? You could try using epoxy on the wire get a nice size glob of it on there where the wire got cut.
Posted on Jan 21, 2007
  • 59 Answers
SOURCE: panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Posted on Oct 23, 2007
Slinteriors
  • 8617 Answers
SOURCE: Convergence Resistors
Can you check that location number again The parts list doesnt list a capacitor with that location number. Is the item a resistor or a capacitor ? Let me know the other site I work at has full service manuals with part numbers and specs in them. I will be able to tell you the specs on your part
Posted on Mar 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Oct 14, 2008
  • 7 Answers
SOURCE: I need to identify the
The resistor you see is a 2.2 ohm 2 watt resistor and is part of the convergence circuitry. I would replace R7011. 7012, 7013, 7014, 7015 & 7016 (all the same value) and the 2 STK392-110 Convergence ICs. This should fix your problem. You can find kits on-line for around $45 with the IC's and resistors together.
Posted on Dec 02, 2008
My 51" Panasonic CinemaVision rear-projection HDTV
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 12, 2013 | Televison & Video
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
Hello need help on tv set
SHORT is on the 140 volt line--usually the horizontal output transistor is shorted, and there may be a simple reason for this.
Let me know if you are able with help to test the part indicated. I know the best way to work on this set safely and quickly.
I am in San Diego, and my name is Steve.
SD TECH
Jun 04, 2010 | Panasonic PT-53WX52 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic rear projection 53" TV model PT-51hx43G. Just got this bad boy back from my ex wife and when i turn it on the power led flashes 3/5 times and goes dim. I have checked the power and...
count the led blink as thats an error code. If it blinks three times its indicating the convergence Circuit has failed. Let me know the actual blink number and I will assist you.
Jun 22, 2009 | Panasonic PT-51HX43 51" Rear Projection...
Panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Oct 31, 2008 | Televison & Video
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
518 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
