Question about Amana Cooktops
Burner is on high all the time
The large double burner is on high all the time whether you are using the whole burner or just the inner smaller burner. The other 3 burners work properly.
    President:
  • 2,761 Answers
Is this an older unit - 5 years or more in use? Sounds like the burner element is shot. Check the Amana web site for a replacement.
Bill B.
San Antonio
Posted on May 12, 2009
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Burner not working
try to clean the injector if no gas came out.or try to use matches to have a flame, i think there a problem in ur spark igniter if the gas is going out.tnx
Nov 22, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
May 14, 2008 | Jenn-Air JED8430 Electric Cooktop
Problem with double burner Jenn-Air JED8430 Electric Cooktop
It's an ignition switch. don't change the burner cartridge.
May 10, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
336 people viewed this question
Top Amana Cooktops Experts
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
