Th-R1 no pwoer to subwoofer - transformer u/s?
We have no power going to the subwoofer. Checked the plug fuse and the 3 internal fuses, they are all ok. My father checked and reccons it could be the transformer.
  • philbeaumont Oct 14, 2007
    how do i fix the transformer?
  • jefffirth Jun 01, 2008
    same problem - sound like I need a transformer. Where can I get it from?
My power goes to the subwoofer and the little green light comes on for just a second and the you hear a click sound and the subwoofer power goes out. I have the JVC DVD Digital Cinema System TH-C90. Can you please help???
Posted on Nov 13, 2008
  • 4,889 Answers
It is the transformer..fix it and everything will be fine!
Posted on Oct 14, 2007
Onkyo skw 591 light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
My JVC TH-C5 System subwoofer has power problem. when i plug it, the power light is not showing. electrician checked the power panel but can't find a solution. please if u can help, reply! thanks. waiting...
Did ur techman checked the fuse?
Normally, that is the one first to be BUSTED before everything else?
If there are no POWER at all the POWER IC is the culprit, and check the DiODES!
Tell me more!
Nov 29, 2010 | JVC TH-C5 System
The mains input fuse (4amp) and a (1amp) fuse on the main power out board were blown. Replaced fuses and switched on, blown again, disconnected output from transformer to main board (4amp) fuse did not...
The cheapest option is to replace the transistors (a quick check on google will tell you how much they are). If they are common transistors you will be able to find them and get them quicker then searching for a board that could be no longer being made.
Sep 02, 2010 | Mackie SWA1501 Subwoofer
Powered Subwoofer repair--- Transformer issues?
Well yes transformers do fail and the transformer does say it has an internal fuse fitted which might have failed. The fuse on the board blowing is an indication of overload. The fact it didn't blow again shows that it is not getting any power or the fault has gone (doubtfull).
I doubt the transformer is a step up. But follow the circuit on the pc board till you come to electroytic capicator. This will have a voltage on it. The power level will be no more and perhaps less than the voltage on the capacitor. Another clue to the power level is if the secondary wires are narrower than those that go to the mains. That will indicate that less voltage comes out.
OK what to do. Well most makers say that the transformer is a safety item so it has to be replaced with the same type or one which is approved by the maker. So you can either contact the maker direct or find a service center, (for the brand) which might order you a replacement, or take the transformer to Radio Shack with details of the model number of the Sub, and see if they can get it for you. While there have a look at the multimeters. You should find one that will help you for all your future needs. I recomend one with a scale (rather than a digital). They are some around for £10 to £20 (I know you live in the USA but you can convert it) that will do what you might need it for.
The first thing to do if you get a meter is check with the ohm setting diodes or bridge rectifiers for shorts. IE: as if you had touch both probes together! Also do the same with any transitors you might find. As this could be the cause of the fuse blowing, and even the transformer's failure.
Mar 23, 2010 | Onkyo SKW-200 Subwoofer
No power i have checked the fuse in the plug and the lead is fine. Yamaha Ysp1000 sound system
There well my be some internal fuse. If the unit is self powered then the amp may have a problem.
Dec 11, 2009 | Yamaha YSP-1000 Main / Stereo Speaker
KEF Subwoofer PSW2010 (KHT2005.2) - No power
chik power sours first
thaen chik transformer inside
u will see it burned if so chang it
Aug 18, 2009 | KEF Audio KHT 2005.2 System
No power to speakers
sounds as if the internal fuse as gone look and replace ?
Dec 22, 2007 | JVC TH-M303 System
725 people viewed this question
