Question about Garden
I have an RZT50 Cub Cadet Mower that only starts with jump
I have an RZT50 lawn tractor bought new in 2006 that has had to be jump started since I bought it. I have replaced the battery recently, again and with full charge, engine will only click. Fuse is good, ground is good. Unit is garage kept. After jump start mower runs excellent and will occasionally start without jump.
  • Anonymous Mar 16, 2014
    can you jump start the Autocraft battery (U1R-2) in my Husqvarna tractor from my automobile?
  • 74 Answers
It sounds like the starter motor is pulling to many amps for the battery to cope with. if its a 12v system it should not pull the battery down to less than 8.5 volts on cranking if it does the starter-motor is defective you can check this with a volt meeter across the battery terminals and see what it read as you crank the engine. hope this helps
Posted on May 12, 2009
I HAVE A RZT50 AND THE FUSE MELTED AND TRACTOR DYED AND WONT CRANK OR START AFTER REPLACING FUSE HOLDER AND FUSE
I HAVE TEH SAME PROBLEM. MY BATT. WAS NOT GOOD. BUT NOW MY BLADES WONT ENGAGE BUT WILL START WITH THE NEW BATT.
Jun 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Apr 15, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet z54 will no start
one of the safety switches are bad it could be the seat are the clutch are the blade switch you can try jumping a wire to the posts after you unplug them one at a time
Jun 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Replacing governor on Cub Cadet 1225
I have a cub cadet 1864 and the governor is out of control, the engine will race a high speeds. When i pull back the governor arm and hold it it run normal. Can some one help
Apr 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
386 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
