Question about Gateway GT4024 PC Desktop
Smart drive failed during diagnostic test
I was having problems with my programs s pop up occured saying error in disk and then gave some codes so I ran the computer through a diagnostic test and it failed the hard drive at the smart drive test. Is it on its way out?
  • marksplace7 May 12, 2009
    Thanks, I thought so needed second opinion,,,Thanks again
  • 2,404 Answers
Bad sectors are starting to show up on the hard drive. Thats what the smartdrive program is for, its checks the hard drive to see if there are any bad spots or potential bad spots on the platter inside of the hard drive.
It will definitely have to be replaced. Replace it with a new one and if you can't then at least replace it with a known good used one.
Posted on May 12, 2009
Hello when I try start my laptop I get a little blue box saying : selected boot image did not authenticate. Press enter to continue. When I do this it shuts itself down. I tried starting it in safe mode...
There are serious errors on you hdd and the system sees it as a hdd failure and consequetially it won't boot. Place your OS disc in the dvd drive, boot from it and choose repair.
Jul 28, 2014 | Computers & Internet
Smart test failed on the drive
A smart failure warning is an internal hard disk drive self-diagnostic that will help predict a failure of the hard disk drive. Any system that is displaying a SMART error should immediately have any important data backed up as the drive is not reliable and is impending failure if it hasn't failed already.
Resolution is hard disk drive replacement, Generally around $100 depending on size and speed of replacement HDD
Jan 25, 2011 | HP Pavilion Slimline s3700y Desktop,...
I have a problem with my dell studio laptop stating like smart hard disk failure in statrup and asks to hit F1 to continue..please give a solution for this problem...
Normally the SMART error occurs when the hard drive has gone bad.. What you do is.. Try running the dell diagnostics by turning on the computer holding the FN key.. It will run some tests... If it provides any error code then the Hard drive has gone bad you need to replace it.. Call up the Dell or a local tech and replace the hard drive
Oct 06, 2010 | Dell Studio 15 Laptop
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
ERROR CODE 2000-0142
Hard drive is failing. Reseat hard drive cables. If it does not work, have to replace hard drive. probably damage from overheating or powersurges.
May 15, 2010 | Dell Studio 17 Laptop
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
I have an Acer Aspire 3680 and about a month ago I had to replace my hard drive because it said a failure was immiment. I ordered the recovery disc from acer and totally re-done my laptop. Well last night,...
Whilst this error can occur due to a faulty hard drive or corrupt page file, but is also a symptom of faulty RAM memory. Unless you have heard "clunking" noises from your new hard drive, its unlikely to be the new disk this time.
Re-seat the memory first. If you have two memory modules installed try removing one at a time (see page 67 of the manual here ftp://ftp.work.acer-euro.com/notebook/aspire_5600/manual/AS%205600_3680.pdf )
Check the System Log in Event Viewer for additional error messages that might help pinpoint the device causing the error. Disabling memory caching of the BIOS might also resolve it. Finally, if all the above steps fail to resolve the error, take the system to a repair facility for diagnostic testing. If you the laptop is overheating, or you can't hear the fan running then fan failure might also be a possible cause.
Dec 11, 2009 | Acer Aspire 3680 Laptop
Dell XPS One, Vista, Seagate Hard Drive failing?
go to pcpitstop.com and run full test. But it sounds like spyware to me.
Sep 15, 2009 | Dell XPS One Red Desktop Computer
"a disk error occured during a write operation" in file summary
It's not a problem with the hard drive, that's for sure. It's something with the music file. You will be able to see that if you move the file to a removable media or another hard drive you will most likely not be able to edit the properties. I don't know what the problem is though, just saying that the hard drive isn't bad. If you want a clarification, you said you had a Dell Computer. When booting up hit F12 and run Diagnostics. It should go through an auto set of diagnostics and then allow you to select what you want to run. Run full diagnostics on your hard drive. Any failure and you should replace the drive.
Mar 19, 2009 | Dell InspironTM 1501 Notebook
SMART error
i think u have to try to RE-install OS
Nov 03, 2007 | HP Compaq Presario v3000z Notebook
Gateway GT4024 PC Desktop Logo
196 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
