Question about JVC Televison & Video
Yellow input/output cable broken off in TV
So... my cat freaked out and ran through our TV wires, yanking out the yellow input/output cord. Unfortunately, the tip of the cord is now stuck IN the back of the TV, and I can't figure out how to get it out. I tried using tweezers (with no power to the TV) but they don't fit. The TV works fine, but the DVD player seems likely to be problematic. Help!
    Sergeant:
    Champion:
  • 255 Answers
You can use a screw small enough to fit in the middle of the tip of the cord.the tip is hollow so just remove any plastic or hard rubber that is clinging on the said tip.(use a big needle for this.)be careful when doing this.make sure that the unit is turned off and unplugged.after inserting the small screw,slowly twist and try to pull it gently until the screw is tight enough but not breaking, to pull the tip.
Posted on May 13, 2009
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
Hooking up my DVD player to my TV and get sound but no video!
dvd player yellow output into
tv yellow input
dvd player white output into
tv white input
dvd player red output into
tv red input
if still no pic replace cords
Dec 31, 2008 | Televison & Video
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Televison & Video Logo
1,167 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
