Question about Traxxas Rc Revo Nitro Monster Truck
How come my revo 3.3 has more power in the front and not the rear. and would it be cause it has a drive kit only in it.
Check your hex hubs they may have stripped out. My revo did this and ruined a wheel it was on the rear too. Hope it helps
Posted on Jun 08, 2009
What causes rear wheels not to engage whether in 2 or 4 whhel drive? Front ones only turn when in 4x4.
If the shaft is powering out to rear end then internal on rear possibly broken differential. If no power from case to rear then broken in case.
May 31, 2015 | Cars & Trucks
Mitsubishi hdtv 1080 what are the blinking green light codes
ost models have a self-diagnosis feature to help determine shutdown problems.
To enable this feature do the following....
1) Turn the tv on and then let it shutdown
2) Press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds
3) After 5 seconds the power LED on the front panel will blink a two digit sequence.
This will commonly be one set of blinks followed by a short pause then another set of blinks.
This will repeat around five times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short detected - commonly caused by convergence failure - to repair this check out site for a convergence kit)
2 - 3 = Deflection protect
2 - 4 = Vertical protect
Note: A constant blink on certain models will typically be caused by a fault in the DM model. To repair this check out site a "blinking green light kit"
Aug 05, 2014 | Mitsubishi WS-55513 55" Rear Projection...
My Pride Revo Mobility scooter needs a new gear box.
never said how old it is,cant give you a good answer without knowing.
Sep 13, 2012 | Pride Mobility Revo 3 Wheel Scooter
Green light on front of TV keeps blinking after power outage. I have tried powering back off and on and resetting the tv. Nothing works
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
Aug 02, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The motor on our brand new Revo 3 Wheel makes a ticking noise about every revolution of the wheels. This is our second Revo, the company exchanged the first one due to the same problem that they could not...
Trent I had this with another scooter and it turned out to be a cut or piece missing from one of the tires. Check all the tires carefully for any little defect or gouge. If you find something fishy take a piece of tape and cove the defect and the drive the scooter and see if you still hear the ticking sound. If that doesn't help block the rear of the scooter off the floor and have your wife run it slowly carefully listen to both rear tires to see if you can find the one making noise. If you can't hear the noise block up the front tires spin them to listen for the sound you are hearing. Hope this helps and let me know what you find Good Luck
Oct 01, 2010 | Pride Mobility Revo 3 Wheel Electric...
Power light blinks 3 times, no picture
Thats usually caused by the cp150, CP120 or CP114 capacitor having failed. You can get the repair kit by the same name from www.tvrepairworld.com The kit contains the caps and the instructions.
Jun 03, 2010 | RCA HD52W56 52" Rear Projection HDTV
Sticking in and out of gear
Hi. When you say in and out of gear, does it free-wheel or just not drive? The jerking could be caused by faulty motor brushes. Fitting new brushes or getting the motor overhauled would probably fix this.
If you gave a better description of the fault, we might be able to give you a better solution. good luck. Neil.
Feb 10, 2010 | Pride Value Line Revo Scooter 3 Wheel
I replace the bulb and I'm getting a blinking error code 3 4. How do I fix? Mitsubishi WD-52525
That code can often be caused by failed capacitors on the power board which will cause the 34 error for lamp abnormality. The V26 Power repair kit at www.tvrepairworld.com may fix that issue. The kit contains the replacement capacitors and has the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I need a price for Front forks
You might be best servered by taking your list to your local HD dealer, or calling say a Dennis Kirk, ot J&P Cycles. As they can give you best prices on the package for the parts you need.
Oct 06, 2009 | 2001 Harley Davidson FXST Softail Standard
Revo 3.3 driving problem
Not 100% sure, but it sounds like you shredded one of your diffs, try turning your wheels by hand and see if you can isolate the sound. When you get down to a quarter of a tank your car will usually run at a slightly leaner mixture creating more power and also more heat. The extra power may have been the cause of your problems.
Jun 10, 2009 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Rc Revo Nitro Monster Truck Logo
152 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
