Question about Black & Decker Black and Decker & Grass Hog Electric Trimmer
Bump feed doesn't work
I recently found an older B & D STA4000 which runs great. I can't get the bump feed to work. Is there a part that fits under the spool to push it back out so it will feed?
4 Suggested Answers
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
SOURCE: Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Posted on Apr 07, 2009
  • 133 Answers
SOURCE: i have a black & decker gt701 strimmer. i
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
I changed the string in my ryobi 725r and since then it feeds the string so fast it wraps around the shaft. What did I do wrong?
multiple failures with bump advance string trimmers - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Jul 5, 2008 - I have indeed hurled my own ryobi across the yard in a fit. ... Some heads are not designed for curved shaft trimmers or on engines under a .... the fence so thestring won't wrap around the fence instead of whipping in and out.
Sep 30, 2015 | Ryobi Garden
Recently purchased 2006 forenza 5 speed 80,000 steers runs great but something in suspension makes car feel like you are driving a trampoline the car just bounces excessively any ideas?
There is a recall on some power steering systems pressure switches or resetting computer call and find out need Vin number good luck
Jun 20, 2014 | 2007 Suzuki Forenza Sedan
My honda xr125 will not electric start but will bump start straight away,i had it from new so i know its not been in accident or breakdown before,when i press starter the solonoid clicks but doesnt turn...
check the battery , even new they will discharge,, if you can jump start it, or at least try, if it works, its going to be low amps in the battery itself, if that doesn't work, your going to have to pull the starter and bench check it,, if you need help with that just reply to this feed and I'll help you with that
Sep 09, 2011 | 2008 Honda XR 125 L
I have a new Pope Renegade 26cc Line Trimmer. Started it up but the cutting line bump feed would not operate. Removed the spool from the spring head and the line was tangled. I removed the tangled line...
Hi John, I have exactly the same problem. I can't go further than about 5 feet before I need new line. I can't help, but I thought you might like to know you are not the only one having problems with this trimmer!!
Sep 09, 2011 | Toro Garden
Lost owners manual, how do I advance the string
Hi don watts46...
Bump the rotating end of the trimmer on the ground while it is running and it will automatically feed the line out, the more you bump the more line feeds out.
Please take time to rate me
Aug 20, 2011 | Troy Garden
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
Hi, I have opel corsa 1.4. Recently i faced a problem that if if there is at least three person (including driver) then during running a tortling noise comming from the right side of the back whenevr it...
the best way to find out what it is would be to have the 3 people in the car while gently pushing down on the car simulating a pot hole or bump and inspecting how the exhaust & shocks in that area where you hear the noise, are fitting. It sounds as if when the weight of the extra passengers is in the vehicle, probably your exhaust pipe/muffler/tailpipe is now closer than usual to another body part & when you hit bumps or pot holes, the extra force caused makes it bump or rub.
Generaly there should always be 1" of exhaust clearance from other parts. There could also be a problem with the shock/strut when the extra weight is placed on it. The noise should actually point you in the best direction & you should look for shiny spots on metal, pipes or things that appear to be capable of rubbing. Sometimes, the muffler /exhaust will lose one or more of the rubber O-rings it is supported by and that allows it to swing & bump making noise. Good luck.
Jan 31, 2010 | 1996 Chevrolet Corsica
Cant get the spool off homelite trimmer
Unscrew the bump-knob and the rest pulls off. If it won't unscrew you could always cut it off and buy a new one from ALM Manufacturing 01423 797208
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Black & Decker Black and Decker & Grass Hog Electric Trimmer  Logo
184 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
