Question about Samsung HP-S5073 50 in. Plasma HDTV
I had two capacitors in my 50mf231d/37 50 inch plasma tv go out.
I replaced the two capacitors and now the tv comes on as normal but I cannot get the picture to come on I hear the soun but no pic. When I first powered it up the picture came on briefly and then went out. Any suggestions? Thanks
  • kitchenandba May 13, 2009
    When you say sustain boards is that the same thing as the upper buffer? LJ41-03882A?? Thanks for the help
    Sergeant:
    Champion:
  • 227 Answers
Your problem is in the Y or Z sustain boards i just fixed one of this today with the same exact problem and i replaced  the Y sustain BINGO.
good luck
caypianan@yahoo.com
Posted on May 12, 2009
  • ESTEBAN MERINO
    ESTEBAN MERINO May 13, 2009
    no, they are located on the left and right side of the screen
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
Dec 10, 2009 | Televison & Video
Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 20, 2009 | Philips 42PF9631D 42 in. Plasma Television
Wont turn on
Take the back off of the TV and look at the power supply board (middle of the set). One or more electrolitic capacitors will have the tops swelled up. Replace them with the same value parts and you will be OK.
May 17, 2009 | Philips 50MF231D 50 in. Plasma Television
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
50" Magnavox Plasma TV will not turn on - Red LED blinking 4x
When you have the red light that blinks four times on the 50" Magnavox Plasma Model 50MF231D/37, you should look for the capacitors on the power board in the center of the of the TV. Look for two 3300uf, 10V, 105c capacitors that have a build up of pressure that has caused the top of the capacitor to look rounded instead of the flat top that will be on all of the other capacitors. Changing these two capacitors fixed the problem of the TV not coming on.
I had more trouble finding the capacitors than changing them. I could not find them locally so I went to an on-line electronics supply store where they were $1.65 each and $8.99 to ship.
Jan 03, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Magnavox 50MF231D/37 Plasma tv
The plasma panel in most cases exceeds the cost of replacing the TV. There is also the issue that they tend to use different versions and makes of panels in these sets. Some panels are made by Samsung and some are made by LG. I would start shopping for a replacement TV at this point.
Feb 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung HP-S5073 50 in. Plasma HDTV Logo
343 people viewed this question
Jerry Greenberg
Jerry Greenberg
