Need a wiring diagram for mastercool evap 2 stage unit
I need to find a wiring diagram for a Mastercool evap cooler that has the ''precooler'' unit attached. The wiring I need to repair in in the control box mounted on the side of the unit which has a capacitor and 4 relays inside. Thei controls the fan motors, and pumps from the controling thermostat in the house.
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
Posted on Jun 06, 2009
  • leentom87 Apr 03, 2011
    i need the same diagram can you please send it to me. thanks in advance
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
I have a MasterCool II MC63/64B and the thermostat has gone out. Since MasterCool is out of business, what model/brand would I replace it with.
If you are just running the evaporative cooler any single stage thermostat will suffice. You can buy them at OSH, Home Depot or Lowe's and probably Ace Hardware.
Aug 03, 2011 | Mastercool 67680 Evaporative Cooler Air...
Does it need to be cleaned, if so. how is that done? AdobeAir /Mastercool model P700 serial number B150809633
Yes, it needs to be cleaned. Go to your local home store and (in the evap cooler section) pick up a bottle of evap cleaner/scale remover. Just follow the directions on the bottle. It will last MUCH longer with proper care and cleaning.
Jul 06, 2010 | Mastercool Portable Air Conditioner
Wiring issue on mastercool 5 CFM 2 stage pump
Black wire is " hot" White wire is: neutral Green wire is ground
This is for 110v AC
Apr 25, 2010 | Mastercool (MSC90066) 5 CFM Economy Series...
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
I need a wiring diagram for a mastercool evaporative cooler
Here is a link to the owners manual for the new Symphony brand evaporative cooler. Symphony is the new name for the old Adobeair brands Mastercools.
The owners manual will have the motor and pump wiring schematic.
Sep 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
I need some help knowing the pump I need
Since adobe air is out of business, you will have to make one of the dial 230 volt pumps fit in its place. I cut a little notch into the media support tray to fit mine.
As far as the pump size goes, the orange 230 volt is somewhere around 11'000cfm or bigger and works just fine in my precooler.
Aug 03, 2009 | Mastercool 67680 Evaporative Cooler Air...
Low voltage wires
I just tested a mastercool control box and found these 4 control wire colors:
Red (24v supply)
White (pump)
Green (low blower)
Yellow (high blower)
The yellow acted as a common for testing when the blower was not on high.
Blower on low just green has 24v.
Blower on high green and yellow have 24v.
If there was a fifth wire added hopefully it would be a ground wire.
There was also the low gauge wires that were black, white, and ground that were not control wires and delivered power to the control box.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Heating & Cooling Logo
1,927 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
