Question about Landice L8 LTD Cardio Trainer Treadmill
Pulley slipping on front roller
Drive sheave or "pulley" is slipping on the front roller. Belt stops and it makes a loud whining sound.
  • 83 Answers
Since the drive pulley is slipping on the roller itself, then the front roller will need to be replaced.
Posted on Apr 30, 2010
  • TreadTech Feb 03, 2011
    I am a treadmill technician and this is a common problem which occurs with both the L8 and L9 Landice treadmills.
    The drive pulley and the front roller both have interlocking ridges on the inside of the pulley and the outside of the front roller.
    The ridges on one or maybe both of the components have worn away and are no longer catching and keeping the compononents from moving as one.
    In my experience it is normally the Pulley which is worn, and it makes sense as it's only a plastic or nylon pulley where as the roller is steel.
    Pull the pulley off the roller and it will be clear which part needs to be replaced. Best of luck
I have nordictrack A2105 and although we "oiled" the belt and replaced motor belt, it still slips. What are we doing wrong?
remove the hood. Turn the treadmill on to speed of 4 or 5 and straddle the walk belt. While the treadmill is running (with good shoes on) step hard on the walkbelt while observing the motor belt and front roller belt pulley. Does just the belt or front roller stop? if so the belt is loose. If the belt does not stop check to see if the front roller stops and the front roller pulley keeps going. If so the front roller pulley is slipping on the roller. If the belt, pulley and front roller are all moving and the walkbelt is the only thing that stops when stepped on then the walk belt is loose. To repair a slipping front roller you have 2 options: 1) purchase a new roller assy or 2) loosen the motor belt and push it to off to the side of the front roller pulley (no needto remove). Realign the roller pulley to the motor pulley. You may have to tap it into alignment. On the inside section of the grooved part of the pulley drill an 1/8" hole thru the pulley and thru the roller housing. (If you drill to the outside portion of the pulley on the left hand side you will hit the roller bearing. Now take a larger drill bit like a 3/8" and lightly countersink the plastic pulley - try not to drill thru the pulley with the larger bit. Using a thin head sheetmetal screw, install the screw so the head is just below the ribbed surface of pulley. If you screw up your first attempt just rotate everything 90° and try again.
Nov 11, 2014 | Nordic Track Nordictrack A2105 Treadmill...
Replacing a belt
Replacing the Drive Belt
IMPORTANT: To aid in reassembly, note the orientation
of the drive belt on the two idler pulleys and the engine
flywheel pulley prior to performing the following steps.
Refer to Figure 10.
The edger drive belt is subject to wear and should be
replaced if any signs of cracking, shredding or rotting
are present. To replace the belt, proceed as follows:
1. Working in front of the edger, loosen the flange
lock nut on top of frame, allowing the idler pulley
assembly to pivot slightly out from the frame. See
Figure 10.
2. With your other hand, carefully reach under the
rear of the unit and remove the belt from around the
engine flywheel pulley.
3. Remove the spindle sheaves belt guard by removing
the two self-tapping screws which secure it to the
blade plate assembly. See Figure 10.
4. Carefully remove the belt from the pulleys,
again making sure to note the orientation of the belt.
Discard the belt.
Install the replacement belt (Part No. 754-04032B) in the
same configuration that the original belt was routed as
follows:5. Working from the front of the edger, place the belt onto
the spindle sheaves, route it back onto the two idler
pulleys, and then place it onto the engine flywheel
pulley.
IMPORTANT: Make certain that the "V" side of the belt
is seated into the top pulley and the flat side of the belt is
seated into the bottom pulley.
6. Reinstall the spindle sheaves belt guard with the self
tapping screws removed earlier.
7. Make certain that the drive belt is on the engine
flywheel pulley and idler pulleys, and retighten the
flange lock nut on the top of the frame.
IMPORTANT: Make certain that the drive belt is seated
correctly and that it is riding smoothly on the spindle
sheaves and is not pinched between them. Repeat the
first three steps if the belt is pinched.
You don't want the belt pinched between those spindle sheaves...trust me ;)
the manual
Oct 13, 2012 | Troy-Bilt tb554 lawn edger
Belt keeps breaking when put a new one on that controls aternator,water pump,etc on my 1995 Nissan pick up truck
if it keeps breaking you either have atension or alignment problem. Alignment will show on the edges of the belt and you should be able to catch a bit of burnt rubber smell on the belt. Unless you have done major work orpulled something thatbwould have moved a pulley my bet would be on tension. on a serpintine belt there is atensioning pulley and these do wear out. When the tension is out the belt can slap and break
Jun 06, 2012 | 1995 Nissan Pickup
I have a Reebok Vista treadmill, I got it used. I used it about 5 times and now the belt is slipping. Any suggestions?
Watch this Videos:
http://www.youtube.com/watch?v=38w4PkiWIBY
http://www.youtube.com/watch?v=ch6Mix_FV00
You should not adjustthese since they are preset. Tension can be affectedslightly by adjusting the tension of the walking belt but if you have a slippingproblem, the drive belt will require replacement. If yourdrive belt is too loose, it will slip on the front roller pulley or the motorpulley. If it is too tight, it will increase your amp draw to the point thatyou may have an electronics or motor problem. Due to this, it is better to beon the safe side and replace a drive belt rather than riskover tightening it. A drive belt is usually $29.99 or less while many parts youcan damage by over tightening can be more than $300.Additionally, too much tension can cause bearing failure in the motor and thefront roller and front roller pulley failure. It is better to err onhaving the belt a little too tight rather than too loose due to the possibilityof injury if the belt slips. Motor Belt Adjustment-Icon Units Do not remove any of themounting bolts to the motorthese repairs will require 2 9/16" wrenches andmayrequire two people to accomplish the repairs Before beginning this repair: Check to make certain that the drive belt requiresadjustment. Check out belt slipping instructions or with the motor cover removed,walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If theproblem is in the drive belt, eitherthe drive belt will stop when stalled or the front roller will stop whenstalled. If the motor, drive belt, and front roller continue to turn when thewalking belt is stalled, the problem is with the walking belt slipping on thefront roller. If the drive belt continues to turn but the frontroller stalls, you may have a broken front roller pulley. If you need further assistance, please reach me, sincerely G-d bless you.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Oct 26, 2011 | Reebok Vista Treadmill - RBTL13305
My readmill stops in the middle of my workout. I can restart it in about 5 seconds...and it stops again ...feels like the belt is skipping, dragging, or something
Please see the next Videos:
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
Oct 26, 2011 | Exercise & Fitness
My SportsArt 6300 suddenly accelerate from 4 within seconds causing me to fall
Dear Sir:
Hello, I will try to help you, inmediately.
Please follow the next step:
1) Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be
on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack
bolt models will have flat mounts and may contain up to four bolts.
2) Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel
with the drive and walking belts. If your treadmill is not equipped with this bolt, . If your
treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16"
wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for
slipping. If belt continues to slip, repeat Steps If a second attempt does not repair the problem
3) If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover
removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the
problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when
stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem
is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls,
you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will
usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or
replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest
replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual
wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt
dressing may help correct the problem. If not, the drive belt must be replaced.
Please check this video:
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
E.CUADRA
Oct 13, 2011 | Sportsart 6300 Treadmill
Bowflex TC5000 L5 Belt will not move antmore.
Dear Sir:
Hello , I hope everything is fine with your family.
Thank you by your request, and I will help you inmediately.
You have a Mechanical problem, please do the following:
Please do this with carefully!
The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset.
Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it. A drive belt is usually $29.99 or less while many parts you can damage by over tightening can be more than $300.
Additionally, too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure. It is better to having the belt a little too tight rather than too loose due to the possibility of injury if the belt slips.
Motor Belt Adjustment- Icon Units
DO NOT REMOVE ANY OF THE MOUNTING BOLTS TO THE MOTOR. SOME MODELS WILL REQUIRE 2 9/16" WRENCHES AND MAY REQUIRE TWO PEOPLE TO ACCOMPLISH THE REPAIRS
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stallthe belt to make it slip.
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts
. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5.
Step 4-
If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5.
Step 5-
If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The entire front roller assembly repaired or replaced (see the help topic on replacing a pulley) and the drive belt must be replaced. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position.
Thank you in advance, sincerely. God bless you.
If you need further help, please reach me.
E.CUADRA
Sep 27, 2011 | Bowflex TC1000 Treadclimber
The belt skips when walking or running
Take the motor hood off and set aside. Straddle the walk belt and set the speed to 3 or 4. Take one foot and step on the walkbelt hard. While doing this look at the pulley on the front roller. Does just the roller stop and the pulley keeps turning, does the roller and the pulley stop together or does just the walkbelt stop? If the walkbelt is the only thing to stop it is loose. If the pulley, roller and the walkbelt stop the motor belt is loose. If the pulley continues to turn and the roller and walkbelt stop your pulley is slipping on the front roller ( press fit). Two solutions: 1) replace the front roller or 2) pin the front roller to the pulley. Align the pulley roller to the motor pulley by tapping it into position. remove motor belt by loosing motor. Drill 1/8 hole through the pulley and roller. Take a larger drill bit and countersink the pulley hole so the head of a screw will be below the pulley grooves when installed. install the screw. If you mess it up -- turn the pulley and roller and try again. This is a permanent fix for this problem. You may have a little pulley wobble and that is OK.
Jan 15, 2011 | Epic 425 Mx Treadmill EPTL88105 !
Treadmill seems to slip in all speeds when weight is put on it. Changed mother board and checked belt tension all were good. Should this machine be lubed?
Pull the hood off. Stand on the sides of the walk platform and start the belt at 4mph. Take one foot and step on the walk belt hard. Look at the pulley on the front roller. Does the pulley continue to turn while the roller stops? If so, the pulley is slipping in the roller (which is a press fit). Replace the front roller or remove the motor belt from the pulley.Align the pulley with the pulley on the motor by tapping with a mallet. Drill an 1/8 hole throught the pulley and roller. Countersink the pulley hole so a small head screw will be under the pulley groves. Install screw in this hole. This is called pinning and is a pemanent fix. If both the pulley and the roller stop together when the belt is stepped on the motor belt is loose. If only the walkbelt stops when stepped on, the walkbelt is loose.
Epic t60 the front roller stops not the belt on the motor. the belt dosen't slip just the front roller stops turning
The pulley on the front roller is pressed on. Sounds like you pulley has broken free from roller. The front roller needs to be replaced. A quick fix which I've seen last a long time. First verify that this is what your problem is. If it isn't obvious mark roller and pulley, use machine and see if your mark moved. Sounds like yours should pretty easy to tell. If it is indeed lose, mark where pulley sits on the roller. Remove the drive belt. Take a hammer and gently bump pulley to the side. Apply some super glue where pulley normally sits. Bump pulley back into place and let dry. Replace drive belt and check.
Nov 17, 2009 | Icon Epic T60 Treadmill
Landice L8 LTD Cardio Trainer Treadmill Logo
1,458 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
Dave
Duff Howell
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
