Question about Craftsman Garden
Started lawn mower first time of the season and it ran straight for a good 25 monutes with no problems. i turned it off to move it to the front yard andnow wwon't stay running. will only run for 5 to
Started lawn mower first time of the season and it ran straight for a good 25 monutes with no problems. i turned it off to move it to the front yard andnow wwon't stay running. will only run for 5 to 10 seconds.
  • 13 Answers
Immediate thought is that something got ingested into the needle feeding the carb. Might have to remove the carb and clean it out thoroughly to maintain fuel flow through the engine. Generally if it runs a few seconds and shuts down then it is running off the initial burst of fuel and then starving out for any more from there.
Posted on May 13, 2009
  • crazyeyess70 May 29, 2012
    Where is carborator and what does it look like
Engine turns very will but will not start
if the fuel is getting there something to do with the spark. Are all contacts good and clean? check the quality of the spark....see if it is any good.
Jul 19, 2015 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Simplicity citation 52" deck front rollers tear yard when making turns
you need to find the grease fittings for the front rollers or wheels and grease them. this needs to be done often in the cutting seasons.
May 14, 2014 | Simplicity Citation 61" 28HP Zero Turn...
My front wheels one is straight the other is turned out
Check your front axle the solid piece that goes from one front wheel to the other and attaches the front spindles and wheels. Your probably going to find the solid axle (which also goes underneath the front of the tractor) has been bent allowing that wheel to turn outward.
Feb 05, 2014 | Poulan Garden
Pouring straight gas in a 2- cycle mower usually give what results
If you ran it with straight gas more than likely you scored the piston. And cylinder up n now it wont run.
Nov 10, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Jul 29, 2010 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
I have had my Poulan Lawn Mower for 4 years. The model number is 961320020. As I was mowing the lawn today, I thought that it might be running a bit sluggish and it dawned on me that I had not ever added...
Four years without adding or changing the oil?!
I think that was the problem right there.
Mowers need oil changes to protect the cylinder walls and valve guides every 25 hours of operation. Thats usually about one season if your yard is under an 1/3 of an acre.
Your mower ran on almost no oil for the last two years. The normal lawn mower only holds 20 ounces of oil. You topped off with 16 ounces! The four ounces still in the motor were probably so full of dirt and metal particles that it was grease! Which is no help to an engine that gets its lubrication by splash oiling.
Your mower should be oiled with 30 weight non detergent oil. Multi Vis oils are for engines with tighter machined tolerances. Your oil choice is going to go right past the piston rings and valve guides creating gobs of smoke! Go get some 30W ND oil at your parts store and put it in....but run the mower first so you can clean out all the gunk in the oil sump. Run it long enough for the oil to flow easily.
Once you put in the right oil you can run it and try to clear out the remaining multi vis oil.
If it keeps smoking...I would say you have permanent damage to the cylinder wall or valve guides.
Good luck and be careful!
Jun 24, 2010 | Poulan Pro " Pro" Self Propelled Mower
Shuts right down after starting , when i prime it , it just makes a hissing sound
If it started and ran well already this season, then it is probably some blockage in the carb. Does it have gas? If you prime it and it starts and dies, it is most likely the carb or float. You have to take the carb off disassemble and clean it out. It is either some debris in the main jet or a stuck float valve. Clean things up with carb cleaner and put it all back together. Should operate fine them. Good luck.
Jun 14, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Pull rope cord on Yard-Man Mower, gets to a point and seizes. Can turn through it by hand with blade but still stops at that point each time with cord
My mower had the same problem. There was some dirt or debris built up on one side of the blade drive shaft, but once I shot some oil onto the shaft and turned the blade a few times by hand, it ran good again.
Hope that helps!
Apr 28, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
My Toro self perpelled lawn mower starts then conks out.
It sounds like your fuel system is plugged up (or water in the carb) First i would make sure there is good fuel supply to the carb, then if so & not running, I would remove the carb and clean as it appears that it is running properly otherwise. Also check your air cleaner element as it may be totally plugged up.. Hope this helps you, Rick
Apr 26, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
156 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
