Kenmore HE2 Plus Front Load Washer Logo
Posted on May 12, 2009
Will not spin or drain
I have a Kenmore tumble action washing machine 417 and it will no longer spin and drain the water.
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on May 13, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
4045
Points
19
Take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Repair pump on kenmores tumble action washer model 417 44152400
how do you know it is a pump? I'd
check with these parts suppliers. I believe I used their parts about 5 years ago. They were helpful
http://www.repairclinic.com/RepairHelp/Washing-Machine-Repair/11-6-896091-/Kenmore-Washing-Machine-41744152400-Troubleshooting
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
3helpful
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
No Motor Action / No Tumble or Spin / Kenmore 417 4405240
Yes, I am!!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
8helpful
4answers
Kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Alexander
vince
