Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Guitar amp I want to fix my Peavey guitar amp. I need a new volume pot. 71190510 88 36 10KLTN are the numbers written on it. I guess its a 10K ohm potentiometer. Do you have this? It's a funny shape.
  • 631 Answers
You can order parts directly from Peavey. You'll have to call to place the order. You can use the followng email address to check price and availability.
For more information, the third question/answer in the list of FAQs has the phone numbers.
Posted on Oct 16, 2007
Pignose guitar amplifier
If you have one of the older original pignose 7-100 amps the volume pot will be a 10k audio pot. If it's a later model it will be a 50k audio pot and your local Radio Shack should have one and if not they can get one. Or go online to Mouser Electronics, All Electronics or any one you prefer and order it online and it will show up right in your mailbox. Let me know if your pignose is an older original model. If so then you may be able to do me a favor regarding the same model, thanks, Bob
Apr 23, 2013 | Pignose Legendary 7-100 Electric Guitar...
I hav a Silvertone sslb11 bass that needs a new volume pot and don't know wich one to buy. I don't see any part numbers or values printed on the pot. Does anyone know part numbers, brand, or...
I recommend checking music stores in your area for that, it doesn't have to be any specific rating of impedence. Depending on brand, I see guitars with anything from 50 ohms to 250 ohms. This only allows a faster cutoff on volume than others. The most critical action is to have a smooth taper, meaning a straight volume rise or decline versus one that goes down slowly or quickly and suddenly cuts off. Most any guitar volume control from a music store will work just fine. In case I confused you, ohms is the rating of the control, the taper or smoothness is classed as A, B, or C. A is normally for volume controls and B is used mostly for tone controls. Knowing that should give you insight insight to the difference of the controls.
Mar 31, 2013 | Music
Peavey Vypyr 75w
If you hear any difference in the sound while moving the pot and not scratching sounds while moving it then its not the pot...
If i understood the problem right, i have seen it in 2 ELKA guitar amps.
In their case it was the TL072 opamps in the preamp section the problem and i tracked it and it must occured due to no earth connection in the wall socket and as a result to the amp...
Mar 11, 2012 | Peavey Electronics Peavey Vypyr 75 -...
Peavey Audition 110 Combo: When amp is switched on and any guitar played through it comes through extremely loudly compared to the volume it is set at. After a number of dunts with my fist on the top of...
The problem is LIKELY a broken solder joint right at where the leads of the volume pot come through the circuit board. The broken joint will ozidize overnight and then when vibration rattles it it will punch through the oxide. INSPECT all solder for the pot leads. Lood for a TINY grey line in the menicus of the solder where the lead comes through the board.
May 10, 2011 | Peavey Vypyr 30 30watt 1x12 Modeling...
Line 6 AX2 212, Are all of the pots 10K Linear ( apart from the volume which is dual ) or are any Log pots? I have changed the pots for linears as I was suffering intermittent problems, the sound is back...
Given your description of intermittent problems, I would venture an educated guess that the problem was NOT the pots to start with. Usually pots will have a part number and you may find an "A" or a "B" indicating the taper.
Look for a circuit board crack in the vicinity of the guitar input section, especially near the pots. Use a BRIGHT led flashlight from opposite side of the board and inspect all solder joints around the input section.
Line 6 seems to play games with a "guitar sense" line that goes to the DSP so problems with that or a break in the circuit trace could cause the symptom.
Aug 22, 2010 | Music
I need to know the ohm rating for the speaker in a
usually combo amps are 8 ohm for guitar. a 16 ohm speaker load comes into play usually on half stack set ups. danville tec 10d, i would guess a ten inch speaker, which is also very common for guitar amps.
May 15, 2010 | Peavey Pv 2600 Power Amplifier
Dirty high switch on a Crate practice amp
NEVER use switch cleaner such as DeOxit on pots !!!!!
I have used CRC226 available at Home Depot electrical dept.
I SUSPECT that the resistance element in that pot is cracked. This is common if the knob sustained a hit. Replacing the pot is the only cure if the element is cracked.
Reviewing the schematic, ALL audio passes through the wiper on the HIGH tone pots. If the wiper is intermittent, so will be the sound.
If your unit is solid state amp, the pot looks like a 10K ohm LINEAR taper.
If you have a tube type, then the pot is a 250K ohm LINEAR.
Note that the other tone pots in the units are AUDIO tapers, but the high is a linear taper.
Get repair parts from either or
Mar 23, 2010 | Crate Music
Peavey signiture EX wiring
if the signature ex has any special plugs then the actuall diagram for that guitar is needed. but if it uses the standard two or three potential meter ( volume knobs and tone knobs or (pots) ) with a pick up selector and an input. then you can use any guitar wiring diagram and i think you can find that on web. wiring the pick up should be shown in the diagram with the pick up selector.
Feb 23, 2009 | Peavey Music
When I turn the power on on my Peavey blazer 158 guitar amp nothing happens. Is there a fuse?
Hi I have written two troubleshooting guides on the issues you have try them at
Let me know if you still face a problem
Oct 13, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Car Audio & Video Logo
187 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
