Question about Logitech 9311570403 Mouse
Dead Micro-switch Dose Logitech or anyone else do repairs to Logitech mice. My T-CH11 seems to have a dead micro-switch. I have had many mice over the years and this model is by far the best on my wrist. I know your going to tell me to just go buy a new one; and that would be fine, except Logitech no longer make this model. Can it be refurbished? And if so, where?
    President:
  • 2,992 Answers
Unless the mouse uses a real oddball microswitch, it would be fairly simple to unsolder the bad switch and replace it with a new one. I have done this on many mice. You can check with computer shops in your area and see if any of them might try the repair. (A TV shop could also do it, but they're not likely to have a few old mice lying around to take a replacement switch from, while a computer shop probably would.) I have no idea what labor rate the shop would charge, but it would certainly exceed the cost of a new mouse. (The shop I formerly worked at would have charged $20, but this was 5 years ago.) However, it might be worth the cost if what you have can't be replaced with something comparable.
Posted on May 12, 2009
  • 2,404 Answers
If you have an electronics shop in your area I would suggest to go to them cause if the component is a somewhat common item then they wouuld have it and they could replace it. Problem is that the cost of the item would be cheap but the labor could be pricey so get all the costs upfront if they can repair it. Hope this helps.
Have a ge pvm1870sm3ss micro lost power after use open door a couple times came back on did it again after use but now it is total dead can anyone help?
A door switch or two are bad and it took out the main fuse.. Change the door switches and fuse. Get the correct parts and make sure you get the switches in the proper locations and configuration
Jan 26, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Logitech canada310 optical mouse right click problem
the switch under the right button is most likely dead. if the mouse is still under warranty get it repaired
Mar 13, 2012 | Logitech MX 310 Mouse
Problems whit logitech mx518 mouse left click sometimes work and sometime no, how do i fix the left click
It sounds like the micro switch needs replacing inside the mouse. At the end of the day it is probably cheaper and less hassel to go out and buy a new mouse.
Aug 01, 2010 | Logitech MX518 931352-0403 Mouse
My micro innovations mouse will not work please help.
i have a pd905p micro innovations optical travel mouse and it lights up when i plug it into the usb drive but then a bubble pops up and says device not recognized. i have used it before on this computer and it worked fine but one day it started acting up and ever since i have been trying to find away to fix it but i have hit a dead end. can someone please help me?
Sep 28, 2009 | Micro Innovations PD950P Mouse
Logitech GT Driving Force Internal Pedal Control Micro-Switch's
maplins,or online at www.cpc.com. just look for micro switches though and find one similar , youll never find an actual logitec one ,
May 22, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Mouse usb micro receiver
You can send an email to Logitech here:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/ask.php
or you can call customer support at +1 646-454-3200
Monday - Friday: 6am - 6pm PST
Saturday - Sunday: 7am - 5pm PST
and order a new reciever. Unfortunately, it cannot be repaired.
Hope that helps.
Sep 04, 2008 | Logitech MX 1000 Laser Cordless...
T-ch11 driver
Use mw9421enu.exe for the old Trackman Marble T-CH11. Newer mouseware versions do not fully support the Trackman Marble. Well, the mw9791enu.exe driver set works, except no picture of the T-CH11 model is displayed so a generic mouse is all you see. Use the mw9421enu.exe set to operate the T-CH11 with Windows XP.
Mar 20, 2008 | Logitech Trackman Marble Trackball
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Micro Innovations cordless rechargeable laser mouse
See if the mouse has a small reset button. You may have to use a pen or something like it to push and hold the button for a few seconds to reset the mouse. That works for me.
Dec 31, 2007 | Micro Innovations PD7250LSR Wireless RF...
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Logitech 9311570403 Mouse Logo
1,018 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
